[mapserver-users] connect label to features
Jeff McKenna jmckenna at gatewaygeomatics.com
Thu Jun 24 12:37:48 PDT 2021
Luca, I've done more testing and in fact I can get point & line features
(with label leader lines)  to work with that mapfile.  I can now see
Thomas' point, that this is a documentation issue (likely when I
originally documented this I could only get it to work with polygons,
but now when I test I can get points,lines,polygons to work by adapting
that same mapfile).
I'll fix that document now.
If you post your mapfile and data I can test your data locally here.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-06-24 3:12 p.m., Jeff McKenna wrote:
> Hi Luca,
> I agree with your thoughts that it would be nice if it worked with
> points as well.  (I don't believe that I ever had it working locally
> with anything but polygons)  Please definitely file a ticket.  Thanks!
> -jeff
> On 2021-06-24 2:29 p.m., Luca Delucchi wrote:
>> On Thu, 24 Jun 2021 at 19:08, Jeff McKenna
>> <jmckenna at gatewaygeomatics.com> wrote:
>>> Hi Luca,
>> Hi Jeff,
>>> I had created that page that Thomas pointed to, I see that my test files
>>> are still available that I used to generate those map images
>>> (https://download.osgeo.org/mapserver/tickets/label-leader.zip).  Give
>>> that mapfile a try with your local MapServer instance, and let me know
>>> if I need to update that test package.
>> I tested that data and it work properly, but as Thomas reported it
>> seems to work only with polygon, with my point data it doesn't work
>> Should I open a enhancement (or bug) issue? I think it should be
>> useful to have it at least for points, but also for line
>>> -jeff
>> Thanks for your help
More information about the MapServer-users mailing list
