[mapserver-users] connect label to features
Jeff McKenna jmckenna at gatewaygeomatics.com
Fri Jun 25 05:21:22 PDT 2021
Hi Luca,
I was able to get leader lines with your data by just commented out your
MINDISTANCE parameter in your LABEL.  Here is the resulting map image:
https://pasteboard.co/K8eUIip.png
Hope that helps.
(please also never attach zip, images, or files, on a mailing list,
instead just upload your zip or image somewhere, and point to it here
instead)
Have a nice weekend,
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2021-06-24 6:57 p.m., Luca Delucchi wrote:
> Hi Jeff,
> On Thu, 24 Jun 2021 at 21:37, Jeff McKenna
> <jmckenna at gatewaygeomatics.com> wrote:
>> Luca, I've done more testing and in fact I can get point & line features
>> (with label leader lines)  to work with that mapfile.  I can now see
>> Thomas' point, that this is a documentation issue (likely when I
>> originally documented this I could only get it to work with polygons,
>> but now when I test I can get points,lines,polygons to work by adapting
>> that same mapfile).
> Thanks a lot, I tried again changing some parameters but I didn't get
> any leader lines.
> I'm using mapserver 7.6.2 provided by Debian
>> I'll fix that document now.
>> If you post your mapfile and data I can test your data locally here.
> here you are an example not working for me, with my output png
>> -jeff
More information about the MapServer-users mailing list
