[mapserver-users] connect label to features
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Fri Jun 25 06:40:21 PDT 2021
All,
My original need for the label lines was for labeling point clusters, I wanted to see a label for each point.  Having said that I understand the reasoning behind the logic we're seeing.  I would suggest that  along with "FORCE TRUE" that some sort of related min-distance (MINLEADERDISTANCE?) type of variable be added directly related to leader lines and when they come on/off by scale, or MINDISTANCE working inside s separate STYLE block (Does it work that way now?) for Leader lines.  I think multiple STYLE blocks came after LEADERs . . . .
bobb
On 6/25/21, 8:28 AM, "mapserver-users on behalf of Jeff McKenna" <mapserver-users-bounces at lists.osgeo.org on behalf of jmckenna at gatewaygeomatics.com> wrote:
    Think Before You Click: This email originated outside our organization.
    Hi Luca,
    The implemented leader label logic does not turn on leader lines for
    every point or feature.  (I believe this is what is causing the
    confusion, as reported by you and Bob)   I personally could see a new
    parameter in the LEADER object of "FORCE TRUE" being very useful, but
    that would take a champion to file a new ticket
    (https://github.com/MapServer/MapServer/issues), create a small test
    case (use yours, but also include the symbolset and fonts that your
    mapfile references, so a developer can just execute shp2img
    out-of-the-box), and then nudge/test/give feedback throughout the whole
    development process.
    Hope that explains more what is happening.
    -jeff
    Jeff McKenna
    GatewayGeo: Developers of MS4W, MapServer Consulting and Training
    co-founder of FOSS4G
    http://gatewaygeo.com/
    On 2021-06-25 9:21 a.m., Jeff McKenna wrote:
    > Hi Luca,
    > I was able to get leader lines with your data by just commented out your
    > MINDISTANCE parameter in your LABEL.  Here is the resulting map image:
    > https://pasteboard.co/K8eUIip.png
    > Hope that helps.
    > (please also never attach zip, images, or files, on a mailing list,
    > instead just upload your zip or image somewhere, and point to it here
    > instead)
    > Have a nice weekend,
    > -jeff
    mapserver-users mailing list
    mapserver-users at lists.osgeo.org
    https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
