[mapserver-users] CGI variable "map" fails to validate.
David Pavlíček
pavlicek.david at gmail.com
Thu Jun 3 05:29:21 PDT 2021
Hi Steve,
your pattern works like a charm... escaped hyphen was the issue. I tested
the previous regex with regex101.com and it matches with no problems
against most of the available variants except PCRE. Which regex engine is
suitable for a test against MapServer?
Thank you.
st 2. 6. 2021 v 15:16 odesílatel Steve Lime <sdlime at gmail.com> napsal:
> Hi David: Presumably the Docker image is running the most recent version
> of 7.4 which would have that pull request applied. That said, I don't think
> it's the culprit here and I have seen some issues with -'s where the
> MS_MAP_PATTERN expression compiles fine but doesn't match as expected.
> Re-writing the expression to move the - character can help. Try this:
> MS_MAP_PATTERN=^\/etc\/mapserver\/([^\.][-_A-Za-z0-9\.]+\/{1})*([-_A-Za-z0-9\.]+\.map)$
> --Steve
> On Wed, Jun 2, 2021 at 3:07 AM David Pavlíček via mapserver-users <
> mapserver-users at lists.osgeo.org> wrote:
>> Hello,
>> I'm using camptocamp/mapserver:7.4 docker image to run mapserver on our
>> servers and I have recently encountered this error:
>> [warn] [pid 25] mod_fcgid: stderr: msCGILoadMap(): Web application error.
>> 2098 - 172.17.0.1 - - [02/Jun/2021:04:57:42 +0000] "GET
>> /?map=/etc/mapserver/puobod/krpk-puobod-red.map&request=getcapabilities&service=WMS"
>> In fact, any mapfile with hyphens won't work. They fail against
>> MS_MAP_PATTERN regex or something. This is strange because I tested this
>> regex and it works fine. Container MS ENV variables look like this:
>> MS_ERRORFILE=stderr
>> MS_MAP_PATTERN=^\/etc\/mapserver\/([^\.][_A-Za-z0-9\-\.]+\/{1})*([_A-Za-z0-9\-\.]+\.map)$
>> MS_DEBUGLEVEL=0
>> MS_MAPFILE=/etc/mapserver/mapserver.map
>> Maybe something related to this PR:
>> https://github.com/MapServer/MapServer/pull/6314
>> Any suggestions about that? Renaming project is not an option because
>> they are referenced in many places outside of our direct reach (GIS
>> clients, servers, etc)
>> Thanks, David
>> mapserver-users mailing list
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210603/2727fbbc/attachment.html>
