[mapserver-users] How to use MS_ENCRYPTION_KEY with AWS connection
Seth G sethg at geographika.co.uk
Tue Mar 2 14:07:27 PST 2021
Hi Jaime,
I believe the encryption key can only be used for some connection types (I know for example it is not implemented currently for SQL Server). Docs report the following as supported:
OGR
Oracle Spatial
SDE
https://mapserver.org/utilities/msencrypt.html#purpose
Regards,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Tue, Mar 2, 2021, at 10:26 PM, Jaime Valdez wrote:
> Hi,
> I'm trying to setup a mapfile by using and encrypting AWS credentials into CONFIG parameters, but it is not working.
> `CONFIG "AWS_ACCESS_KEY_ID" "{ ... }"`
> `CONFIG "AWS_SECRET_ACCESS_KEY" "{ ... }"`
> `CONFIG "AWS_DEFAULT_REGION" "{ ... }"`
> When I change into plain AWS credentials works. I have use MS_ENCRYPTION_KEY in the past when connecting to PostGIS.
> Kind regards.
>  Jaime E. Valdez  ☎  + 52 442 168 8006
> mapserver-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210302/81eba032/attachment.htm>
More information about the MapServer-users mailing list
