[mapserver-users] BINVALS is supported by PostGIS 1.5?
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Fri Mar 26 01:08:59 PDT 2021
Developers have paid attention to BINDVALS recently https://github.com/MapServer/MapServer/issues/6236 and they should work as in your mapfile.
The usage example is about string "1" "Nova Scotia". I wonder how a numeric bindvalue should be expressed in mapfile. Could it be that in the "1" "10" case the value gets converted into SQL string '10'?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Fujioka (Duke)
Lähetetty: perjantai 26. maaliskuuta 2021 6.01
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] BINVALS is supported by PostGIS 1.5?
Hello Mapserver experts!
I googled BINVALS but couldn't find any useful information.
What I want to achieve is to include a placeholder in DATA and substitute it using BINVALS.
Simplified example:
LAYER
CONNECTION "user=xxx password=xxx dbname=xxx host=xxx"
CONNECTIONTYPE POSTGIS
DEBUG 5
DATA "geom from (select column1, geom, count(*) from table1 where
column1 = $1 group by column1, geom) AS foo USING UNIQUE column1 USING SRID=4326"
BINDVALS
"1" "10"
END
END
I expect the final query would be "select ... where column1 = 10 group by ...". But the map image does not show anything. It's a gray image.
When I set "DEBUG 5" at the layer level and took a look at the debug info, the placeholder was not substituted (it was still "where column1 = $1..."). So, it seems BINDVALS is not working.
Any tips on this? Does the complexity of the query matter (e.g. can't use GROUP BY or JOIN)? Should the query in the debug info be the final one with the placeholder substituted with the value specified in BINDVALS?
I use Mapserver 6.4 & PostGIS 1.5 & PostgreSQL 9.1. Is BINDVALS not supported for these versions?
Also, how can I change the bind value using PHP Mapscript (say, from "10" to "20")?
Thanks,
Ei Fujioka
Research Scientist
Nicholas School
Duke University
(919) 684-3518
efujioka at duke.edu
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
