[mapserver-users] anti-aliasing (was differing image size with different mapserver versions)
Even Rouault
even.rouault at spatialys.com
Tue May 18 10:42:47 PDT 2021
Forcing paletted images using QUANTIZE_FORCE=on and decreasing the number of colors with QUANTIZE_COLORS can also help:
FORMATOPTION "QUANTIZE_FORCE=on"
FORMATOPTION "QUANTIZE_COLORS=200"
Le 18/05/2021 à 19:30, Seth G a écrit :
> I've not used it but the following might help for the AGG/PNG driver:
> FORMATOPTION "COMPRESSION=9"
> https://mapserver.org/mapfile/outputformat.html
> <https://mapserver.org/mapfile/outputformat.html>
> The default is 6.
> web:http://geographika.co.uk
> twitter: @geographika
> On Tue, May 18, 2021, at 7:16 PM, Basques, Bob (CI-StPaul) wrote:
>> All,
>> I know the GD stuff has been a long running conversation in the
>> MapServer realm, but does this indicate that maybe discussing
>> something on adding GD back in might be prudent? Or are there
>> methods to get down to these previous files sizes with the newer
>> approaches?
>> I have the same concerns related to image size from the performance
>> side, and running on Mobile in our case.
>> Bobb
>> *From: *mapserver-users <mapserver-users-bounces at lists.osgeo.org> on
>> behalf of Richard Greenwood <richard.greenwood at gmail.com>
>> *Date: *Tuesday, May 18, 2021 at 11:50 AM
>> *To: *"mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
>> *Subject: *[mapserver-users] anti-aliasing (was differing image size
>> *Think Before You Click: *This email originated *outside *our
>> organization.
>> Thanks to several helpful replies to my previous thread I know that
>> the increased image size between MapServer 6 with the GD driver and
>> MapServer 7 with the AGG driver is due to differences in
>> anti-aliasing (and lack of) in the two drivers. (AGG features
>> anti-aliasing and sub-pixel resolution
>> <https://en.wikipedia.org/wiki/Anti-Grain_Geometry>).
>> Gamma setting from 0-1 affects the size of a filled polygon layer by
>> a factor of almost 3x. But gamma has no effect on text, lines, and
>> polygon outlines. So images comprised of these types of features are
>> approximately 2x larger with the AGG/PNG8 driver than with the GD/GIF
>> driver.
>> Where else should I be looking to reduce my images sizes? I serve
>> rural areas with poor internet so in my case, smaller image sizes are
>> more important than higher quality images.
>> Thanks,
>> Rich
>> Richard W. Greenwood, PLS
>> www.greenwoodmap.com <http://www.greenwoodmap.com>
>> mapserver-users mailing list
>> <mailto:mapserver-users%40lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210518/dd284901/attachment.htm>
More information about the MapServer-users
