[mapserver-users] differing image size with different mapserver versions
Even Rouault
even.rouault at spatialys.com
Sat May 15 10:21:13 PDT 2021
Actually, I just tried to open mapserv64.png with gimp, and export it as
a non-interlaced or interlaced PNG. And the non-interlaced version is 60
kB vs 96 kB for interlaced. So interlacing vs non-interlacing isn't the
cause here.
Looking more closely at mapserv64.png vs mapserv76.png , they are
visually different. I suspect the rendering to be of higher quality in
7.6 due to anti-aliasing and perhaps better quantization to 8-bit. You
could perhaps try to turn off antialiasing in your CLASS.STYLE. This has
been re-vived very recently for AGG line rendering. It is master only
however.
Le 15/05/2021 à 19:07, Richard Greenwood a écrit :
> Even,
> Thank you. I had ignored the difference in the interlacing of the two
> images because I didn't think it would have affected the size.
> The maprgbapng.c file no longer exists in MapServer 6.4 or 7.6. There
> is an "if ( interlaced ..." code block in mapoutput.c that is the same
> in 6.4 and 7.6. I tried forcing it ON and rebuilding 7.6 but the
> output image still is not interlaced. Maybe that code is just a left
> over. Or maybe AGG doesn't support interlacing as
> https://www.mapserver.org/mapfile/outputformat.html
> <https://www.mapserver.org/mapfile/outputformat.html> seems to suggest.
> In any case, thanks again.
> Rich
> On Sat, May 15, 2021 at 9:59 AM Even Rouault
> <even.rouault at spatialys.com <mailto:even.rouault at spatialys.com>> wrote:
> Richard,
> your 6.4 image is a interlaced PNG, whereas the 7.6 is a
> non-interlaced one.
> I see in the git history a relevant commit:
> $ git show 9984b39cc8f74d60eb240728df660a172a118aad
> commit 9984b39cc8f74d60eb240728df660a172a118aad
> Author: Thomas Bonfort <thomas.bonfort at gmail.com>
> <mailto:thomas.bonfort at gmail.com>
> Date: Sun Oct 5 15:59:44 2008 +0000
> rgba_png: don't interlace by default
> git-svn-id: http://svn.osgeo.org/mapserver/trunk@7960
> <http://svn.osgeo.org/mapserver/trunk@7960>
> 7532c77e-422f-0410-93f4-f0b67bdd69e2
> diff --git a/maprgbapng.c b/maprgbapng.c
> index 105d8d61..c3615edd 100644
> --- a/maprgbapng.c
> +++ b/maprgbapng.c
> @@ -357,10 +357,13 @@ int msSaveImageRGBAQuantized(gdImagePtr img,
> gdIOCtx *ctx, outputFormatObj *form
> int bot_idx, top_idx;
> int remap[256];
> int reqcolors = atoi(msGetOutputFormatOption( format,
> "QUANTIZE_COLORS", "256"));
> + const char *interlace;
> ms_png_info info;
> info.width = gdImageSX(img);
> info.height = gdImageSY(img);
> - if( strcasecmp("ON", msGetOutputFormatOption( format,
> "INTERLACE", "ON" )) == 0 )
> + interlace = msGetOutputFormatOption( format, "INTERLACE",
> "OFF" );
> + if( strcasecmp("ON", interlace) == 0 || strcasecmp("YES",
> interlace) == 0
> + || strcasecmp("1", interlace) == 0)
> info.interlaced=1;
> else
> info.interlaced=0;
> But this predates 6.4 release by several years, so this doesn't
> explain why you see a different behavior, unless something in 6.4
> still turned on interlacing on in that configuration.
> From what I can see in the doc, the interlacing mode was removed
> in the 7.0 release when GD went off, so I don't think you can do
> much. I guess that could be re-added but would require some coding.
> Even
> Le 15/05/2021 à 17:43, Richard Greenwood a écrit :
>> I get significantly different image sizes between MapServer 6.4
>> and 7.6 with the same output format definition. I've tried many
>> variations of the following.
>> OUTPUTFORMAT
>> NAME "png-test"
>> DRIVER "AGG/PNG" # GD driver is same (6.4 only)
>> MIMETYPE "image/png; mode=8bit"
>> IMAGEMODE PC256
>> FORMATOPTION "QUANTIZE_FORCE=on"
>> FORMATOPTION "QUANTIZE_COLORS=256"
>> EXTENSION "png"
>> # TRANSPARENT on or off makes little difference
>> END
>> MapServer 6.4 <https://greenwoodmap.com/mapserv64.png> is 90kB,
>> MapServer 7.6 <https://greenwoodmap.com/mapserv76.png> is 320kB.
>> Any suggestions as to how I can get my MapServer 7.6 image sizes
>> down closer to what I'm getting in MapServer 6.4?
>> Thanks,
>> Rich
>> Richard W. Greenwood, PLS
>> www.greenwoodmap.com <http://www.greenwoodmap.com>
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> http://www.spatialys.com <http://www.spatialys.com>
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210515/5da4774b/attachment-0001.html>
