[mapserver-users] mapserver-users Digest, Vol 160, Issue 28
    Marcin Grudzień
    mgrudzien7 at gmail.com
    Tue May 25 02:20:29 PDT 2021
Hi Seth,
It is very basic WFS GetFeature request
http://localhost/cgi-bin/mapserv?map=/srv/lc/LC_wfs.map&SERVICE=WFS&REQUEST=GetFeature&VERSION=2.0.0&COUNT=10&TYPENAMES=LC.LandCoverUnit
On Tue, 25 May 2021 at 11:03, <mapserver-users-request at lists.osgeo.org>
wrote:
> Send mapserver-users mailing list submissions to
>         mapserver-users at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/mapserver-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         mapserver-users-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of mapserver-users digest..."
> Today's Topics:
>    1. Re:  Setting up a template for custom WFS GetFeature response
>       (Seth G)
> Message: 1
> Date: Tue, 25 May 2021 11:02:52 +0200
> From: "Seth G" <sethg at geographika.co.uk>
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users]  Setting up a template for custom WFS
>         GetFeature response
> Message-ID: <dd600931-5920-49ea-b814-84506177a692 at www.fastmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Marcin,
> What does your GetFeature request look like?
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Tue, May 25, 2021, at 10:55 AM, Marcin Grudzie? wrote:
> > Hello,
> > I have been trying to set up INSPIRE WFS service publishing data in GML
> that validates against INSPIRE GML application schemas. To achieve that I
> use template-driven output, basically following
> https://mapserver.org/fr/output/template_output.html. However, I am not
> able to force MapServer to use my GetFeature response template. GetFeature
> response always returns ?standard? MapServer GML, which of course, is not
> INSPIRE compliant.
> > Below you can find my configuration details.
> > I am using 7.6.3 version build on Ubuntu 20.04 LTR
> > mapserv -v returns
> > MapServer version 7.6.3 OUTPUT=PNG OUTPUT=JPEG SUPPORTS=PROJ
> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=ICONV
> SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WFS_SERVER
> SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=GEOS SUPPORTS=POINT_Z_M
> SUPPORTS=PBF INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> > My mapfile looks like this
> > MAP
> > NAME "LandCover"
> > STATUS ON
> > EXTENT 160828.34326572 98928.8977745594 876029.97009323 796521.669409553
> > UNITS meters
> > SIZE 100 100
> > MAXSIZE 4000
> > FONTSET "/srv/Fonts/Fontset.txt"
> > CONFIG "MS_ERRORFILE" "/srv/lc/error_lc_wfs.txt"
> > DEBUG 5
> > PROJECTION
> > "init=epsg:2180"
> > END
> > OUTPUTFORMAT
> >             NAME "gml"
> >             DRIVER "TEMPLATE"
> >             #MIMETYPE "text/xml; subtype=gml/3.2.1"
> >             FORMATOPTION "FILE=LC_template.gml"
> > END
> > WEB
> > METADATA
> > "ows_inspire_capabilities" "url"
> > "ows_languages" "pol,eng"
> > "ows_title" "Title PL"
> > "ows_title.eng" "WFS service with INSPIRE Land Cover"
> > "ows_abstract" "Abstract PL"
> > "ows_abstract.eng" "WMS service publishes harmonised INSPIRE Land Cover
> data set derrived from BDOT10k as-is data set "
> > "ows_fees" "Brak op?at"
> > "ows_fees.eng" "No fee applies"
> >  WFS_ONLINERESOURCE "http://localhost/cgi-bin/LC_WFS"
> > "wfs_getfeature_formatlist" "gml"
> > "wfs_inspire_metadataurl_href"    "someurl"
> > "wfs_inspire_metadataurl_format"
> "application/vnd.ogc.csw.GetRecordByIdResponse_xml"
> > "ows_inspire_dsid_code" "LC "
> > "ows_inspire_dsid_ns" "LC.3.2"
> > "wfs_enable_request"           "*"
> > "wfs_srs" "EPSG:2180 EPSG:4326 EPSG:3857 EPSG:4528"
> > END
> > END #WEB
> > LAYER
> >             NAME "LC.LandCoverUnit"
> >             STATUS ON
> >             CONNECTIONTYPE POSTGIS
> >             CONNECTION "host=localhost dbname=postgis_db user=user
> password=password port=5432"
> >             DATA "geom from bdot.landcoversurface using unique objectid
> using srid=2180"
> >             PROJECTION
> >                         "init=epsg:2180"
> >             END
> >             TYPE POLYGON
> >             PROCESSING "CLOSE_CONNECTION=DEFER"
> >             TEMPLATE "LC_template.gml"
> >             METADATA
> >                         "ows_title.pol" "LC.LandCoverUnit"
> >                         "ows_title.eng" "LC.LandCoverUnit"
> >                         WFS_EXTENT "160828.34326572 98928.8977745594
> 876029.97009323 796521.669409553"
> >                         "gml_include_items" "all"
> >                         "gml_featureid"     "objectid"
> >                         "wfs_connectiontimeout" "120"
> >                         "wfs_maxfeatures"       "10000"
> EPSG:4528"
> >                         "wfs_metadataurl_href" "someurl"
> "application/xml"
> >                         "wfs_metadataurl_type" "TC211"
> >               END #METADATA
> > END #LAYER
> > END #MAP
> > I tried different OUTPUTFORMAT configurations with different NAME,
> MIMETYPE parameter values. And nothing has worked.
> > On the same machine, I successfully published WMS service returning HTML
> GetFeatureInfo response customized utilizing the very same template-driven
> output concept.
> > I suspect that I may be missing something in the configuration file. I
> would be grateful for any suggestions.
> > Best regards,
> > Marcin
> > mapserver-users at lists.osgeo.org <mailto:
> mapserver-users%40lists.osgeo.org>
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210525/41fcc396/attachment.html
> Subject: Digest Footer
> End of mapserver-users Digest, Vol 160, Issue 28
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210525/a81daa87/attachment.htm>
More information about the MapServer-users
