[mapserver-users] WFS Client returns data at random with very same call
    Even Rouault
    even.rouault at spatialys.com
    Fri May 28 04:55:12 PDT 2021
oops, sorry, didn't notice 😅
Le 28/05/2021 à 13:52, Lars Fricke a écrit :
> I put in the files as attach. Is that filtered?
> SkenData Email Signatur
> Am 28.05.21 um 13:43 schrieb Even Rouault:
>> Please include your mapfile and the wfs-request-testlayer.xml file to
>> reproduce. I'm confused by the mapfile you posted yesterday that uses
>> epsg:25832 and the fact that GDAL through mapserver would issue a
>> GetFeature in EPSG:3857 as suggested below. I can't see how that
>> could happen (given the MapServer/GDAL integration, GDAL should
>> always request in the native SRS of the layer and MapServer will do
>> the reprojection to the SRSNAME of the WFS request)
>> But as Daniel suggested using the CONNECTION WFS is probably a better
>> way of doing what you want
>> Le 28/05/2021 à 13:13, Lars Fricke via mapserver-users a écrit :
>>> So here is the working not working setup. Unfortunately the working
>>> OGR WFS client layers are all private so I can not share them.
>>> This call delivers objects as expected:
>>> http://localhost:8181/cgi-bin/mapserv?map=/var/www/html/wfs.map&SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&Maxfeatures=10&TYPENAME=TestLayer
>>> This one, too:
>>> Data is delivered in the correct srs (verified manually with QGIS).
>>> This call doesn't work as described before as BBOX is not
>>> transmitted to external server:
>>> http://localhost:8181/cgi-bin/mapserv?map=/var/www/html/wfs.map&SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&BBOX=791880.72463009,6321925.37255709,792929.63787777,6322786.10157277&TYPENAME=TestLayer
>>> While the same direct call works:
>>> http://sg.geodatenzentrum.de/wfs_info?SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&BBOX=791880.72463009,6321925.37255709,792929.63787777,6322786.10157277&TYPENAME=info:dop
>>> (funny, epsg 3857 is not in the capabilities but works anyhow)
>>> I hope you can find out what is going wrong. Thanks so much for
>>> looking into this!
>>> Best
>>> Lars
>>> Am 27.05.21 um 18:28 schrieb Rahkonen Jukka (MML):
>>>> Hi,
>>>> Have you already tried to use WFS connection instead of OGR connection?
>>>> -Jukka Rahkonen-
>>>> *Lähettäjä:* mapserver-users
>>>> <mapserver-users-bounces at lists.osgeo.org> *Puolesta *Lars Fricke
>>>> *Lähetetty:* torstai 27. toukokuuta 2021 14.59
>>>> *Vastaanottaja:* mapserver-users at lists.osgeo.org
>>>> *Aihe:* Re: [mapserver-users] WFS Client returns data at random
>>>> with very same call
>>>> Dear all,
>>>> I apologize for finding and posting bits and pieces not all at one
>>>> time.
>>>> I fired up 'CONFIG "CPL_DEBUG" "ON"' and there I see, that
>>>> HTTP:
>>>> Fetch(http://url-to-external-server?SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=1000&REQUEST=GetFeature&TYPENAME=dop
>>>> <http://url-to-external-server?SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=1000&REQUEST=GetFeature&TYPENAME=dop>)
>>>> So there is no BBOX. On other layers I see
>>>> GDALOpen(/vsicurl_streaming/https:...
>>>> with BBOX.
>>>> No wonder I do not get reliable results if the server is calling
>>>> some 1000 whatsoever result objects and starts filtering the bbox
>>>> after.
>>>> Any idea what is happening? Or is this something for a GDAL thread?
>>>> Best
>>>> Lars
>>> mapserver-users mailing list
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> http://www.spatialys.com
>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210528/b6f0667c/attachment.htm>
More information about the MapServer-users
