[mapserver-users] Mapscript C# and OWSRequest parameters
Jelmer Baas
jelmerbaas at nedgraphics.nl
Mon May 31 01:45:25 PDT 2021
Hi all,
Well, that route was a short one. Yes, I can call installStdinFromBuffer, but actually reading something via bufferRead:
int msIO_bufferRead( void *cbData, void *data, int byteCount )
(void)cbData;
(void)data;
(void)byteCount;
/* not implemented yet. */
return 0;
Unless I’m missing something, this isn’t possible, yet. I find it hard to believe no-one uses MapServer to handle WFS Post requests, so I’m pretty sure I’m missing something?
Regards,
Jelmer Baas
From: mapserver-users <mapserver-users-bounces at lists.osgeo.org> On Behalf Of Seth G
Sent: donderdag 27 mei 2021 20:35
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Mapscript C# and OWSRequest parameters
Hi Jelmer,
I think you'd have to use mapscript.msIO_installStdinFromBuffer to read data in.
See https://mapserver.org/development/rfc/ms-rfc-16.html#io-hooking although I'm not sure if the approach works or was fully implemented.
Let us know how you get on,
Seth
web:http://geographika.co.uk
twitter: @geographika
On Thu, May 27, 2021, at 10:39 AM, Jelmer Baas wrote:
Hello,
For a new project, I’ve decided to pickup MapScript again to function as an internal (back-end) WFS server. I use the OWSRequest class, which works fine when I fill it with loadParamsFromURL() – in the case of Get requests.
I can’t seem to figure out a way to get my POST data into this object, though. It has a loadParams method, but because I’m not running as a CGI application (back-end app without a webserver), this doesn’t do anything. I also tried setting postrequest property and then calling the loadParams, setting Environment variables, etc. No error, no exception, just -1 value from NumParams.
Any suggestions on how to proceed?
Regards,
Jelmer Baas
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users%40lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210531/2eb16134/attachment.htm>
More information about the MapServer-users
