[mapserver-users] Setting up a template for custom WFS
Passmore, James H.
jpass at bgs.ac.uk
Tue May 25 08:10:56 PDT 2021
It's a while since I looked to be honest, but this archived thread suggests similar.
See http://osgeo-org.1560.x6.nabble.com/Mapserver-and-Complex-Feature-support-td5232994.html
I don't know if MapServer now supports GDAL/OGR GMLAS (https://gdal.org/drivers/vector/gmlas.html), if so it may now be possible to provide complex features.
For other FOSS, you can use deegree, and GeoServer (in combination with App-Schema plugin or now/in the near future the Templating plugin).
James
-----Original Message-----
Sent: 25 May 2021 15:15
To: Passmore, James H. <jpass at bgs.ac.uk>
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Setting up a template for custom WFS
Dear James,
Thank you for your answer. Do you know what are the specific limitations of MapServer in this regard?
Can you suggest any FOSS alternatives for publishing complex features via WFS e.g. GeoServer?
Best regards,
Marcin
On Tue, 25 May 2021 at 11:16, Passmore, James H. <jpass at bgs.ac.uk <mailto:jpass at bgs.ac.uk> > wrote:
Hi Marcin,
As far as I am aware, it is not possible to serve up an INSPIRE compliant (complex feature) WFS with MapServer.
James Passmore
British Geological Survey,
Environmental Science Centre,
KEYWORTH,
United Kingdom,
NG12 5GG
orcid: https://orcid.org/0000-0002-9891-6265
Phone: +44 (0)115 936 3125
Skype: BGSjames
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
