[mapserver-users] WFS Client returns data at random with very same call
Even Rouault
even.rouault at spatialys.com
Fri May 28 04:43:53 PDT 2021
Please include your mapfile and the wfs-request-testlayer.xml file to
reproduce. I'm confused by the mapfile you posted yesterday that uses
epsg:25832 and the fact that GDAL through mapserver would issue a
GetFeature in EPSG:3857 as suggested below. I can't see how that could
happen (given the MapServer/GDAL integration, GDAL should always request
in the native SRS of the layer and MapServer will do the reprojection to
the SRSNAME of the WFS request)
But as Daniel suggested using the CONNECTION WFS is probably a better
way of doing what you want
Le 28/05/2021 à 13:13, Lars Fricke via mapserver-users a écrit :
> So here is the working not working setup. Unfortunately the working
> OGR WFS client layers are all private so I can not share them.
> This call delivers objects as expected:
> http://localhost:8181/cgi-bin/mapserv?map=/var/www/html/wfs.map&SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&Maxfeatures=10&TYPENAME=TestLayer
> This one, too:
> Data is delivered in the correct srs (verified manually with QGIS).
> This call doesn't work as described before as BBOX is not transmitted
> to external server:
> http://localhost:8181/cgi-bin/mapserv?map=/var/www/html/wfs.map&SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&BBOX=791880.72463009,6321925.37255709,792929.63787777,6322786.10157277&TYPENAME=TestLayer
> While the same direct call works:
> http://sg.geodatenzentrum.de/wfs_info?SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&BBOX=791880.72463009,6321925.37255709,792929.63787777,6322786.10157277&TYPENAME=info:dop
> (funny, epsg 3857 is not in the capabilities but works anyhow)
> I hope you can find out what is going wrong. Thanks so much for
> looking into this!
> Best
> Lars
> SkenData Email Signatur
> Am 27.05.21 um 18:28 schrieb Rahkonen Jukka (MML):
>> Hi,
>> Have you already tried to use WFS connection instead of OGR connection?
>> -Jukka Rahkonen-
>> *Lähettäjä:* mapserver-users
>> <mapserver-users-bounces at lists.osgeo.org> *Puolesta *Lars Fricke
>> *Lähetetty:* torstai 27. toukokuuta 2021 14.59
>> *Vastaanottaja:* mapserver-users at lists.osgeo.org
>> *Aihe:* Re: [mapserver-users] WFS Client returns data at random with
>> very same call
>> Dear all,
>> I apologize for finding and posting bits and pieces not all at one time.
>> I fired up 'CONFIG "CPL_DEBUG" "ON"' and there I see, that
>> HTTP:
>> Fetch(http://url-to-external-server?SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=1000&REQUEST=GetFeature&TYPENAME=dop
>> <http://url-to-external-server?SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=1000&REQUEST=GetFeature&TYPENAME=dop>)
>> So there is no BBOX. On other layers I see
>> GDALOpen(/vsicurl_streaming/https:...
>> with BBOX.
>> No wonder I do not get reliable results if the server is calling some
>> 1000 whatsoever result objects and starts filtering the bbox after.
>> Any idea what is happening? Or is this something for a GDAL thread?
>> Best
>> Lars
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210528/5cc0b82f/attachment-0001.html>
