[mapserver-users] WFS Client returns data at random with very same call
Even Rouault
even.rouault at spatialys.com
Fri May 28 05:32:42 PDT 2021
Lars,
I believe the service you request doesn't implement WFS 1.1 properly.
Trying this
./mapserv
QUERY_STRING="map=wfs.map&SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&BBOX=791880.72463009,6321925.37255709,792929.63787777,6322786.10157277&TYPENAME=TestLayer"
I see that GDAL does:
VSICURL: Start download for
http://sg.geodatenzentrum.de/wfs_info?SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=500&REQUEST=GetFeature&TYPENAME=info:dop&FILTER=%3CFilter%20xmlns%3D%22http:%2F%2Fwww.opengis.net%2Fogc%22%20xmlns:gml%3D%22http:%2F%2Fwww.opengis.net%2Fgml%22%3E%3CBBOX%3E%3CPropertyName%3Egeom%3C%2FPropertyName%3E%3Cgml:Box%3E%3Cgml:coordinates%3E362792.2015953020309098,5459899.7109905285760760%20363491.4383923375280574,5460477.4964771848171949%3C%2Fgml:coordinates%3E%3C%2Fgml:Box%3E%3C%2FBBOX%3E%3C%2FFilter%3E
So Mapserver has transmitted to GDAL a BBOX filter in epsg:25832 (which
is the native SRS of the layer) that is the reprojection of your source
BBOX from EPSG:3857. All things are good up to that point.
But the server returns an empty response.
Tweaking it manually to include a srsName="EPSG:25832" attribute in
gml:Box returns a response with 2 features
http://sg.geodatenzentrum.de/wfs_info?SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=500&REQUEST=GetFeature&TYPENAME=info:dop&FILTER=%3CFilter%20xmlns%3D%22http:%2F%2Fwww.opengis.net%2Fogc%22%20xmlns:gml%3D%22http:%2F%2Fwww.opengis.net%2Fgml%22%3E%3CBBOX%3E%3CPropertyName%3Egeom%3C%2FPropertyName%3E%3Cgml:Box%20srsName=%22EPSG:25832%22%3E%3Cgml:coordinates%3E362792.2015953020309098,5459899.7109905285760760%20363491.4383923375280574,5460477.4964771848171949%3C%2Fgml:coordinates%3E%3C%2Fgml:Box%3E%3C%2FBBOX%3E%3C%2FFilter%3E
But we shouldn't have to do this has a missing srsName should be
interpretated as the defaultSRS according to my understand of the WFS
1.1 spec
You can however tweak the <URL> element in wfs-request-dop-bkg-age and
add "&SRSNAME=EPSG:25832" to it (since it is the defaultSRS of all
the layers of the service), and then GDAL will forward it.
Even
Le 28/05/2021 à 14:11, Lars Fricke a écrit :
> No problem. Unfortunately, testing native WFS did not work because it
> does not properly support cascading wfs with different srs (see my
> other post).
> Thanks for looking into this.
> SkenData Email Signatur
> Am 28.05.21 um 13:55 schrieb Even Rouault:
>> oops, sorry, didn't notice 😅
>> Le 28/05/2021 à 13:52, Lars Fricke a écrit :
>>> I put in the files as attach. Is that filtered?
>>> Am 28.05.21 um 13:43 schrieb Even Rouault:
>>>> Please include your mapfile and the wfs-request-testlayer.xml file
>>>> to reproduce. I'm confused by the mapfile you posted yesterday that
>>>> uses epsg:25832 and the fact that GDAL through mapserver would
>>>> issue a GetFeature in EPSG:3857 as suggested below. I can't see how
>>>> that could happen (given the MapServer/GDAL integration, GDAL
>>>> should always request in the native SRS of the layer and MapServer
>>>> will do the reprojection to the SRSNAME of the WFS request)
>>>> But as Daniel suggested using the CONNECTION WFS is probably a
>>>> better way of doing what you want
>>>> Le 28/05/2021 à 13:13, Lars Fricke via mapserver-users a écrit :
>>>>> So here is the working not working setup. Unfortunately the
>>>>> working OGR WFS client layers are all private so I can not share them.
>>>>> This call delivers objects as expected:
>>>>> http://localhost:8181/cgi-bin/mapserv?map=/var/www/html/wfs.map&SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&Maxfeatures=10&TYPENAME=TestLayer
>>>>> This one, too:
>>>>> Data is delivered in the correct srs (verified manually with QGIS).
>>>>> This call doesn't work as described before as BBOX is not
>>>>> transmitted to external server:
>>>>> http://localhost:8181/cgi-bin/mapserv?map=/var/www/html/wfs.map&SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&BBOX=791880.72463009,6321925.37255709,792929.63787777,6322786.10157277&TYPENAME=TestLayer
>>>>> While the same direct call works:
>>>>> http://sg.geodatenzentrum.de/wfs_info?SRSNAME=EPSG:3857&SERVICE=WFS&VERSION=1.0.0&REQUEST=GetFeature&BBOX=791880.72463009,6321925.37255709,792929.63787777,6322786.10157277&TYPENAME=info:dop
>>>>> (funny, epsg 3857 is not in the capabilities but works anyhow)
>>>>> I hope you can find out what is going wrong. Thanks so much for
>>>>> looking into this!
>>>>> Best
>>>>> Lars
>>>>> Am 27.05.21 um 18:28 schrieb Rahkonen Jukka (MML):
>>>>>> Hi,
>>>>>> Have you already tried to use WFS connection instead of OGR
>>>>>> connection?
>>>>>> -Jukka Rahkonen-
>>>>>> *Lähettäjä:* mapserver-users
>>>>>> <mapserver-users-bounces at lists.osgeo.org> *Puolesta *Lars Fricke
>>>>>> *Lähetetty:* torstai 27. toukokuuta 2021 14.59
>>>>>> *Vastaanottaja:* mapserver-users at lists.osgeo.org
>>>>>> *Aihe:* Re: [mapserver-users] WFS Client returns data at random
>>>>>> with very same call
>>>>>> Dear all,
>>>>>> I apologize for finding and posting bits and pieces not all at
>>>>>> one time.
>>>>>> I fired up 'CONFIG "CPL_DEBUG" "ON"' and there I see, that
>>>>>> HTTP:
>>>>>> Fetch(http://url-to-external-server?SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=1000&REQUEST=GetFeature&TYPENAME=dop
>>>>>> <http://url-to-external-server?SERVICE=WFS&VERSION=1.1.0&MAXFEATURES=1000&REQUEST=GetFeature&TYPENAME=dop>)
>>>>>> So there is no BBOX. On other layers I see
>>>>>> GDALOpen(/vsicurl_streaming/https:...
>>>>>> with BBOX.
>>>>>> No wonder I do not get reliable results if the server is calling
>>>>>> some 1000 whatsoever result objects and starts filtering the bbox
>>>>>> after.
>>>>>> Any idea what is happening? Or is this something for a GDAL thread?
>>>>>> Best
>>>>>> Lars
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> http://www.spatialys.com
>>>> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210528/0fb5b513/attachment-0001.html>
