[mapserver-users] Mapscript C# and OWSRequest parameters
Seth G
sethg at geographika.co.uk
Mon May 31 03:59:21 PDT 2021
Actually as there are no URL limits with MapScript you should be able to add your filter as a WFS GET parameter and skip using POST requests altogether.
https://www.mapserver.org/fr/ogc/filter_encoding.html#tests
web:http://geographika.co.uk
twitter: @geographika
On Mon, May 31, 2021, at 10:45 AM, Jelmer Baas wrote:
> Hi all,
> Well, that route was a short one. Yes, I can call installStdinFromBuffer, but actually reading something via bufferRead:
> int msIO_bufferRead( void *cbData, void *data, int byteCount )
> (void)cbData;
> (void)data;
> (void)byteCount;
> /* not implemented yet. */
> return 0;
> Unless I’m missing something, this isn’t possible, yet. I find it hard to believe no-one uses MapServer to handle WFS Post requests, so I’m pretty sure I’m missing something?
> Regards,
> Jelmer Baas
> *From:* mapserver-users <mapserver-users-bounces at lists.osgeo.org> *On Behalf Of *Seth G
> *Sent:* donderdag 27 mei 2021 20:35
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] Mapscript C# and OWSRequest parameters
> Hi Jelmer,
> I think you'd have to use mapscript.msIO_installStdinFromBuffer to read data in.
> See https://mapserver.org/development/rfc/ms-rfc-16.html#io-hooking although I'm not sure if the approach works or was fully implemented.
> Let us know how you get on,
> Seth
> On Thu, May 27, 2021, at 10:39 AM, Jelmer Baas wrote:
>> Hello,
>> For a new project, I’ve decided to pickup MapScript again to function as an internal (back-end) WFS server. I use the OWSRequest class, which works fine when I fill it with loadParamsFromURL() – in the case of Get requests.
>> I can’t seem to figure out a way to get my POST data into this object, though. It has a loadParams method, but because I’m not running as a CGI application (back-end app without a webserver), this doesn’t do anything. I also tried setting postrequest property and then calling the loadParams, setting Environment variables, etc. No error, no exception, just -1 value from NumParams.
>> Any suggestions on how to proceed?
>> Regards,
>> Jelmer Baas
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org <mailto:mapserver-users%40lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210531/122ea776/attachment.html>
