[mapserver-users] msCGILoadMap(): Web application error. CGI variable "map" is not set
Basques, Bob (CI-StPaul)
bob.basques at ci.stpaul.mn.us
Mon Nov 15 10:39:55 PST 2021
Does that MAPFILE actually exist in that location on the server:
map=/ms4w/apps/tutorial/htdocs/example1-1.map
If it does, then you may have a config/permissions problem on the (root of the) server. Mac OS has it’s own web service for example and it sometimes takes a little fiddling to get add-on working.
Bobb
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> on behalf of "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Reply-To: Kenneth Kniel <kkniel at mac.com>
Date: Monday, November 15, 2021 at 12:19 PM
To: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] msCGILoadMap(): Web application error. CGI variable "map" is not set
Think Before You Click: This email originated outside our organization.
Mac OS 11.6.1
Mapserver 7.6.4. Homebrew install
Working my way through the tutorial. Going slow a lot of permission issues.
The Mapserver is running I go the no query response when I access from the server.
Trying to run the first example
//localhost/cgi-bin/mapserv?%20map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map<http://localhost/cgi-bin/mapserv?%20map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map>
Getting error in subject line above.
Thoughts?
Thanks in advance.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211115/15d84609/attachment.htm>
More information about the MapServer-users
