[mapserver-users] Comment on OpenStreetMap tutorial...
Carl Godkin cgodkin at gmail.com
Tue Nov 16 10:32:17 PST 2021
Hi (mostly Jeff),
I am going through the excellent MapServer + OpenStreetMap tutorial that
you produced at
https://github.com/mapserver/mapserver/wiki/RenderingOsmDataWindows .
As you know, it's several versions behind but everything works fine up to
one spot.
Under "Verify PostgreSQL and PostGIS Installation Success" I don't see the
"template_postgis" database discussed under the 7th bullet point:
   - There should be an icon with a red X labeled something like
   "template_postgis" (databases created by postgis install)
.  Instead, I only see the default "postgres" database.  There is a clue
that says
   - Single click 'template_postgis" (Note: with PostgresSQL 11
   Stackbuilder this will not be there; create a db and add the extensions
   yourself using pgAdmin)
but although I was able to create a database called "template_postgis," I
was unable to add the postgis and postgis_topology extensions, perhaps due
to my unfamiliarity with the pgAdmin tool.
I think that the reason is due to the third bullet point under "Install
PostGIS" which says
   - Make sure "Create Database" is not selected
perhaps?  Anyway, I found a workaround.
I opened back up Stack Builder, and reinstalled PostGIS and this time
checked the "Create Database" option.  I named the database
"template_postgis" and the new database seems to be fine.
I would consider making a PR for this page if you thought this was the
right approach.
I am using Postgres 14 on Windows 10 with MS4W 4.0.5 and so far, so good!
Thanks,
carl
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211116/6dacc598/attachment.htm>
More information about the MapServer-users mailing list
