[mapserver-users] Corrupted PNG issue
Steve Lime sdlime at gmail.com
Mon Nov 22 08:16:57 PST 2021
John: What happens if you take WMS out of the equation, so:
  mapserv.exe -nh "QUERY_STRING=
--Steve
On Fri, Nov 19, 2021 at 1:01 PM John Huotari <John.Huotari at rcis.com> wrote:
> Thanks for the feedback Jukka, Steve, and Seth.
> Using mapserv.exe –nh at the command line produces the same corrupt PNGs
> as I get through a web server.
> Using MapServer 7.7.0dev from MS4W as Jukka suggested produces good PNGs,
> so that’s a viable alternative for me.
> I’ve done some playing around with different versions available from
> GISInternals and it appears that PNG images generate fine up through their
> GDAL 3.2.1 and MapServer 7.6.2 version
> (release-1900-x64-gdal-3-2-1-mapserver-7-6-2), but started producing
> corrupt PNGs in their GDAL 3.2.2 and MapServer 7.6.2 version
> (release-1928-x64-gdal-3-2-2-mapserver-7-6-2).
> If anyone with Windows wants to attempt to reproduce, the older
> GISInternals versions are available here:
> https://www.gisinternals.com/archive.php
> And the .map file I’m using for testing this is just hitting a
> publicly-available WMS.
> MAP
>   NAME "MAP"
>   CONFIG "MS_ERRORFILE" "c:/temp/ms_error.txt"
>   CONFIG "PROJ_LIB" "C:/ms/projlib/"
>   EXTENT -20037508.342789244 -20037508.342789244 20037508.342789244
> 20037508.342789244
>   SIZE 256 256
>   SYMBOLSET "c:\ms\symbols.txt"
>   FONTSET "c:\ms\fonts.txt"
>   IMAGECOLOR 255 255 255
>   TRANSPARENT ON
>   DEFRESOLUTION 72
>   RESOLUTION 72
>   UNITS meters
>   PROJECTION "init=epsg:3857" END
>   WEB
>     METADATA
>       "wms_enable_request" "*"
>     END
>   END
>   LAYER
>     STATUS DEFAULT TYPE RASTER NAME "WMS_DRG"
>     CONNECTIONTYPE WMS CONNECTION "
> https://basemap.nationalmap.gov/arcgis/services/USGSTopo/MapServer/WmsServer
>     METADATA
>       "wms_srs"  "EPSG:3857"
>       "wms_name"  "0"
>       "wms_server_version"  "1.1.1"
>       "wms_format"  "image/png"
>     END
>   END
> END
> *From:* Steve Lime <sdlime at gmail.com>
> *Sent:* Thursday, November 18, 2021 8:53 AM
> *To:* John Huotari <John.Huotari at RCIS.com>
> *Cc:* mapserver-users at lists.osgeo.org
> *Subject:* [EXTERNAL] Re: [mapserver-users] Corrupted PNG issue
> Hmmm... I've not run into or heard of this before although I'm not a
> windows user. I did a quick sanity check with a mapfile here and the latest
> 7.4 and 7.6 versions. While not exactly the same setup you have in terms of
> versions, they produce the exact same png image.
> What do you get for output if you use mapserv.exe at the command line? So
> something like:
> map=dynamic\5708d96b-c606-4c35-95e7-085fedc1dcce.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=MAP&TILED=true&WIDTH=512&HEIGHT=512&CRS=EPSG%3A3857&STYLES=&BBOX=-10877294.873093722%2C5536486.832751887%2C-10876071.880641159%2C5537709.82520445"
> That would take PostMan and the web server out of the picture. Is there
> any chance different versions of libpng are being used? What are you using
> to manage the tiles?
> --Steve
> On Wed, Nov 17, 2021 at 4:57 PM John Huotari via MapServer-users <
> mapserver-users at lists.osgeo.org> wrote:
> I’m attempting to upgrade from MapServer 7.6.1 to 7.6.4 via compiled
> packages obtained from GISInternals.  I’m running it on Windows/IIS and
> whereas 7.6.1 was generating .PNG tiles perfectly for me, after upgrading
> to 7.6.4, the .PNGs being created appear to be corrupt.  I can replace the
> 7.6.4 exe and dlls with 7.6.1 versions and the PNG images generate fine
> again, so while there are quite a few places that could introduce an issue,
> with the exception of a change to MapServer everything would be identical
> in my stack between having the issue in 7.6.4 and not in 7.6.1.
> The good headers from 7.6.1 look like this
> 89 50 4e 47 0d 0a 1a 0a  00 00 00 0d 49 48 44 52
> and the corrupted ones from 7.6.4 look like this
> 89 50 4e 47 0d 0d 0a 1a 0d 0a 00 00 00 0d 49 48 44 52
> It appears that the 0a values from the valid header are being converted to
> 0d 0a.  I might be wrong here, but it appears to me that something is
> interpreting the 0a as a line feed and given the code is running on
> Windows, is converting that LF into a CR LF.  The replacement doesn’t seem
> to be limited to the file header as I see the 7.6.4 version of the file is
> slightly larger (18,571 bytes instead of 18,407 bytes) and in spot
> checking, I’ve verified some additional 0d’s exist precede 0a within the
> data blocks of the .PNG.  Has anyone experienced anything like this or know
> of any fixes?
> PNG Images produced on the server with shp2img are just fine, it’s only
> images produced by making a WMS request to mapserv.exe that have the
> issue.  An example WMS request would be
> https://<Server
> <https://urldefense.com/v3/__https:/*3CServer__;JQ!!G6MNE2S8Nw!x_ksvCCfwXPiXznbuHZekzR6wQvjCERh2SpiB7YOgt5igg_PFub0fYqcSN2m4Zmt$>
> Name
> Removed>/mapserv.exe?map=dynamic\5708d96b-c606-4c35-95e7-085fedc1dcce.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=MAP&TILED=true&WIDTH=512&HEIGHT=512&CRS=EPSG%3A3857&STYLES=&BBOX=-10877294.873093722%2C5536486.832751887%2C-10876071.880641159%2C5537709.82520445
> Maybe I’m completely misdiagnosing the problem as these PNG image files
> just show up as corrupted within a browser – for example FireFox reports
> “The image <full URL here> cannot be displayed because it contains
> errors.”  The way I obtained the actual .PNG images to view in a binary
> editor was to use PostMan and save the body of the results.  Perhaps
> PostMan introduced the extra bytes when saving an unrecognizable format
> file to disk whereas it did not when saving a file it recognized as a valid
> PNG.  I can’t find anything different between the valid and invalid files
> beyond the extra 0d’s that have been added though, so I don’t think PostMan
> or anything else in the chain introduced them.
> ******************* PLEASE NOTE *******************
> This message, along with any attachments, is for the designated
> recipient(s) only and may contain privileged, proprietary, or otherwise
> confidential information. If this message has reached you in error, kindly
> destroy it without review and notify the sender immediately. Any other use
> of such misdirected e-mail by you is prohibited. Where allowed by local
> law, electronic communications with Zurich and its affiliates, including
> e-mail and instant messaging (including content), may be scanned for the
> purposes of information security and assessment of internal compliance with
> company policy.
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> <https://urldefense.com/v3/__https:/lists.osgeo.org/mailman/listinfo/mapserver-users__;!!G6MNE2S8Nw!x_ksvCCfwXPiXznbuHZekzR6wQvjCERh2SpiB7YOgt5igg_PFub0fYqcSI16O73t$>
> company policy.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211122/5f85785b/attachment.htm>
More information about the MapServer-users mailing list
