[mapserver-users] Corrupted PNG issue
Even Rouault
even.rouault at spatialys.com
Fri Nov 19 05:07:25 PST 2021
Could be a msIO_needBinaryStdout() missing somewhere. Seth, if you've
the chance to run a git bisect session, that could probably give a
strong hint of how to fix that.
Le 19/11/2021 à 09:43, Seth G a écrit :
> Possibly unrelated but I ran into a similar issue exporting WFS to
> zipped shapefiles.
> Working fine in 7-4-3 but broken in 7-6-4 (and current master) - the
> zip files are corrupt, although they have an identical size.
> 7-zip reports "Headers Error Unconfirmed start of archive"
> The same command is used for both versions:
> mapserv -nh
> "QUERY_STRING=map=my.map&service=WFS&REQUEST=GetFeature&TYPENAME=LayerName&version=2.0.0&outputformat=shapezip&srsName=EPSG:3857"
> > output.zip
> I had a look with a hex editor but the start of the working and
> corrupt zips seem identical.
> On the other hand all PNGs / WMS services are fine.
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Thu, Nov 18, 2021, at 3:53 PM, Steve Lime wrote:
>> Hmmm... I've not run into or heard of this before although I'm not a
>> windows user. I did a quick sanity check with a mapfile here and the
>> latest 7.4 and 7.6 versions. While not exactly the same setup you
>> have in terms of versions, they produce the exact same png image.
>> What do you get for output if you use mapserv.exe at the command
>> line? So something like:
>> mapserv.exe -nh "QUERY_STRING=
>> map=dynamic\5708d96b-c606-4c35-95e7-085fedc1dcce.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=MAP&TILED=true&WIDTH=512&HEIGHT=512&CRS=EPSG%3A3857&STYLES=&BBOX=-10877294.873093722%2C5536486.832751887%2C-10876071.880641159%2C5537709.82520445"
>> That would take PostMan and the web server out of the picture. Is
>> there any chance different versions of libpng are being used? What
>> are you using to manage the tiles?
>> --Steve
>> On Wed, Nov 17, 2021 at 4:57 PM John Huotari via MapServer-users
>> <mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>> wrote:
>> I’m attempting to upgrade from MapServer 7.6.1 to 7.6.4 via
>> compiled packages obtained from GISInternals. I’m running it on
>> Windows/IIS and whereas 7.6.1 was generating .PNG tiles perfectly
>> for me, after upgrading to 7.6.4, the .PNGs being created appear
>> to be corrupt. I can replace the 7.6.4 exe and dlls with 7.6.1
>> versions and the PNG images generate fine again, so while there
>> are quite a few places that could introduce an issue, with the
>> exception of a change to MapServer everything would be identical
>> in my stack between having the issue in 7.6.4 and not in 7.6.1.
>> The good headers from 7.6.1 look like this
>> 89 50 4e 47 0d 0a 1a 0a 00 00 00 0d 49 48 44 52
>> and the corrupted ones from 7.6.4 look like this
>> 89 50 4e 47 0d 0d 0a 1a 0d 0a 00 00 00 0d 49 48 44 52
>> It appears that the 0a values from the valid header are being
>> converted to 0d 0a. I might be wrong here, but it appears to me
>> that something is interpreting the 0a as a line feed and given
>> the code is running on Windows, is converting that LF into a CR
>> LF. The replacement doesn’t seem to be limited to the file
>> header as I see the 7.6.4 version of the file is slightly larger
>> (18,571 bytes instead of 18,407 bytes) and in spot checking, I’ve
>> verified some additional 0d’s exist precede 0a within the data
>> blocks of the .PNG. Has anyone experienced anything like this or
>> know of any fixes?
>> PNG Images produced on the server with shp2img are just fine,
>> it’s only images produced by making a WMS request to mapserv.exe
>> that have the issue. An example WMS request would be
>> https://<Server Name
>> Removed>/mapserv.exe?map=dynamic\5708d96b-c606-4c35-95e7-085fedc1dcce.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image%2Fpng&TRANSPARENT=true&LAYERS=MAP&TILED=true&WIDTH=512&HEIGHT=512&CRS=EPSG%3A3857&STYLES=&BBOX=-10877294.873093722%2C5536486.832751887%2C-10876071.880641159%2C5537709.82520445
>> Maybe I’m completely misdiagnosing the problem as these PNG image
>> files just show up as corrupted within a browser – for example
>> FireFox reports “The image <full URL here> cannot be displayed
>> images to view in a binary editor was to use PostMan and save the
>> body of the results. Perhaps PostMan introduced the extra bytes
>> when saving an unrecognizable format file to disk whereas it did
>> not when saving a file it recognized as a valid PNG. I can’t
>> find anything different between the valid and invalid files
>> beyond the extra 0d’s that have been added though, so I don’t
>> think PostMan or anything else in the chain introduced them.
>> ******************* PLEASE NOTE *******************
>> This message, along with any attachments, is for the designated
>> recipient(s) only and may contain privileged, proprietary, or
>> otherwise confidential information. If this message has reached
>> you in error, kindly destroy it without review and notify the
>> sender immediately. Any other use of such misdirected e-mail by
>> you is prohibited. Where allowed by local law, electronic
>> communications with Zurich and its affiliates, including e-mail
>> and instant messaging (including content), may be scanned for the
>> purposes of information security and assessment of internal
>> compliance with company policy.
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> <mailto:MapServer-users at lists.osgeo.org>
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
>> MapServer-users at lists.osgeo.org <mailto:MapServer-users at lists.osgeo.org>
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211119/fe7c6af3/attachment-0001.html>
More information about the MapServer-users
