[mapserver-users] WFS bbox/intersect etc query from custom projection to EPSG:4326
Sander Pukk
sander.pukk at gmail.com
Thu Nov 25 04:20:29 PST 2021
Hei!
Thanks, guys!
I tried all the different coordinate orders ( with the good old axis
orientation in mind), but I was missing the layer PROJECTION parameter like
Seth suggested.
It seems it is a combination of three things here:
- PROJECTION missing in LAYER
- Coordinate order in the request
- Wfs_srs needs to be there like it was, but the main one is only
needed. 3301 in my case
All in all, got it working, big thanks :) !
Cheers,
Sander
On Thu, Nov 25, 2021 at 11:12 AM Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> (resending to the list without the original mail, list has rather (too?)
> strict size limits, 40 KB)
> Hi,
> Perhaps you fell into the infamous axis order trap. With WFS 1.1.x and 2.0
> the coordinates of EPSG:4326 most be in latitude-longiture oreder. I
> modified you mapfile a bit for my test data that are in EPSG:3067, and this
> request
> http://localhost:8060/cgi-bin/mapserv.exe?map=c:/ms4w_data/wfstest.map&service=WFS&version=2.0.0&request=GetFeature&TypeNames=ms:testi_virolaisille&BBOX=60.1870614692821,24.9810192523929,60.2794267964524,25.1561900521738,urn:ogc:def:crs:EPSG::4326
> finds buildings from the database. The SQL that Mapserver generates is:
> [Thu Nov 25 10:23:51 2021].654000 msPostGISLayerWhichShapes query: SELECT
> "fid"::text,"id"::text,"mtk_id"::text,"sijaintitarkkuus"::text,"aineistolahde"::text,"alkupvm"::text,"kohdeluokka"::text,"korkeustarkkuus"::text,"kayttotarkoitus"::text,"kerrosluku"::text,"pohjankorkeus"::text,"korkeusarvo"::text,ST_AsBinary(("geom"),'NDR')
> as geom,"fid"::text FROM rakennus WHERE "geom" &&
> ST_GeomFromText('POLYGON((388034.000000002
> 6673671.81841385,388034.000000002 6684239.6439825,398034
> 6684239.6439825,398034 6673671.81841385,388034.000000002
> 6673671.81841385))',3067)
> Notice that the re-projected polygon seems to be the envelope of the
> rotated bbox from the transformation and therefore it is bigger than the
> polygon that would be achieved by connecting the projected corner points as
> this test with gdaltranform shows.
> gdaltransform -s_srs epsg:4326 -t_srs epsg:3067
> 24.9810192523929 60.1870614692821
> 388034.000000002 6673956 0
> 25.1561900521738 60.279426796452
> 398033.999999999 6683955.99999996 0
> I add also my mapfile, I apologize that it is just a fast modification of
> some old mapfile and is not the cleanest possible.
> MAP
> CONFIG "MS_ERRORFILE" "/ms4w_data/ms_error.txt"
> EXTENT 19970 6597278 749676 7785300
> PROJECTION
> "init=epsg:3067"
> END
> OUTPUTFORMAT
> NAME "OGRGML"
> DRIVER "OGR/GML"
> FORMATOPTION "STORAGE=stream"
> FORMATOPTION "LCO:COORDINATE_PRECISION=10"
> END
> OUTPUTFORMAT
> NAME "GeoJSON"
> DRIVER "OGR/GEOJSON"
> MIMETYPE "application/json; subtype=geojson; charset=utf-8"
> FORMATOPTION "FORM=SIMPLE"
> END
> LAYER
> NAME "testi_virolaisille"
> STATUS ON
> DEBUG 10
> TYPE polygon
> PROJECTION
> "init=epsg:3067"
> END
> METADATA
> "ows_title" "viro_testi"
> "ows_abstract" "viro_testi"
> "wfs_getfeature_formatlist" "GeoJSON"
> # "gml_featureid" "id"
> "gml_include_items" "all"
> # "gml_types" "auto"
> "wfs_srs" "EPSG:3067 EPSG:3857 EPSG:4326"
> END
> CONNECTIONTYPE POSTGIS
> CONNECTION "host=localhost port=5432 dbname= user= password= "
> DATA "geom from rakennus using SRID=3067"
> CLASS
> STYLE
> COLOR 255 0 0
> END
> END
> END
> WEB
> MINSCALE 10
> MAXSCALE 1550000
> METADATA
> "wms_title" "wfs_test"
> "wfs_onlineresource"
> http://localhost:8060/cgi-bin/mapserv.exe?map=c:\ms4w_data\wfstest.map
> "wms_srs" "EPSG:4326 EPSG:900913 EPSG:3857 EPSG:31370"
> "wms_enable_request" "*"
> "wms_feature_info_mime_type" "text/html"
> "wms_format" "image/png"
> "wfs_title" "wfs_test"
> "wfs_enable_request" "*"
> "wfs_precision" "10"
> #"wfs_feature_info_mime_type" "text/html"
> END
> END
> END
> -Jukka Rahkonen-
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211125/95861543/attachment-0001.html>
More information about the MapServer-users
