[mapserver-users] (no subject)
Steve Lime sdlime at gmail.com
Thu Oct 7 05:57:13 PDT 2021
I've not used a similar setup but it seems like there's no need to create
tiles if you're passing WMS calls through to another WMS server. Do you get
tiles if you make tiled service requests?
On Tue, Oct 5, 2021 at 1:52 PM Atlanta Geek <atlantageek at gmail.com> wrote:
> Im attempting to configure mapcache.
> I assume that this is covered in this mailing list as well.  Mapcache is
> returning images of the map for me but the cache files are not being
> written.  Its strange because I can use the seeding command with the same
> xml file and its populating the expected directory but when I go through
> the mapcache script its not writing to that cache directory.
> Any guidance would be appreciated.
> The URL Im testing with is this.
> http://192.168.112.225/mapcache?service=WMS&request=GetMap&layers=default&styles=&format=image%2Fpng&transparent=true&version=1.1.1&width=2048&height=2048&srs=EPSG%3A3857&bbox=-10018754.171394622,0,0,10018754.171394628
> mapcache.xml is as follows:
> <mapcache mode="combined_mirror">
>    <cache name="disk" type="disk">
>            <base>/tmp/mapcache</base>
>       <symlink_blank/>
>    </cache>
> <format name="png" type="PNG">
>    <compression>fast</compression>
>    <colors>256</colors>
> </format>
>    <source name="vmap0" type="wms">
>       <getmap>
>          <params>
>             <FORMAT>image/jpeg</FORMAT>
>             <LAYERS>default</LAYERS>
>             <map>/usr/lib/cgi-bin/osm-bw.map</map>
>             <transparent>true</transparent>
>          </params>
>       </getmap>
>       <http>
>          <url>http://192.168.112.225/cgi-bin/mapserv?</url>
>       </http>
>    </source>
>    <tileset name="mirror">
>       <source>vmap0</source>
>       <cache>disk</cache>
>       <grid>WGS84</grid>
>       <grid>g</grid>
>       <format>png</format>
>               <expires>3600</expires>
>    </tileset>
>    <default_format>png</default_format>
>    <service type="wms" enabled="true">
>       <format allow_client_override="true/false">png</format>
>       <full_wms>assemble</full_wms>
>       <resample_mode>bilinear</resample_mode>
>       <maxsize>4096</maxsize>
>       <forwarding_rule name="catch all">
>             <http>
>               <url>
> http://192.168.112.225/cgi-bin/mapserv?transparent=true&map=/usr/lib/cgi-bin/osm-bw.map
> </url>
>             </http>
>       </forwarding_rule>
>    </service>
>    <service type="wmts" enabled="true"/>
>    <service type="tms" enabled="true"/>
>    <service type="kml" enabled="true"/>
>    <service type="gmaps" enabled="true"/>
>    <service type="ve" enabled="true"/>
>    <service type="demo" enabled="true"/>
>    <errors>report</errors>
>    <lock_dir>/tmp</lock_dir>
>    <log_level>debug</log_level>
> </mapcache>
> http://www.atlantageek.com
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211007/c814ca3b/attachment.htm>
More information about the MapServer-users mailing list
