[mapserver-users] Getting started with mapcache for WMTS...
Carl Godkin
cgodkin at gmail.com
Mon Oct 25 16:46:49 PDT 2021
Thanks for the suggestion, Scott. I think the seeder is optional, right?
Anyway, I ended up figuring out that my <source> was wrong in a couple of
ways in mapcache.xml. I misunderstood the
<getmap> parameters. Now I have this:
<source name="faa" type="wms">
<getmap>
<params>
<FORMAT>image/png</FORMAT>
<LAYERS>FAA_Sectional_Charts</LAYERS>
<SRS>EPSG:3857</SRS>
</params>
</getmap>
<http>
<url>http://localhost:8080/wms</url>
</http>
</source>
I wrote a tiny little leaflet test and, after making every possible
mistake, finally
got it all to work so I'm all set. Thanks,
carl
On Mon, Oct 25, 2021 at 3:24 PM Scott <public at postholer.com> wrote:
> Try using mapcache seeder. That will create some cached images to work
> with. It will also test your mapcache config:
> https://mapserver.org/mapcache/seed.html
> How you use those tiles is a whole different subject.
> On 10/25/21 2:54 PM, Carl Godkin wrote:
> > Hi again,
> > Is there a way to search through the mapserver-users mailing list
> > archive except month-by-month? If so, I can't find it. (I usually use
> > my Gmail archives for GDAL and PROJ since I've subscribed forever to
> > those but I'm a mapserver newbie.) Anyway...
> > I am trying to configure mapcache to serve from my (local and AFAICT
> > fully working) WMS server on my MS4W 4.0.5 installation. I am following
> > the directions at https://mapserver.org/mapcache/index.html
> > <https://mapserver.org/mapcache/index.html> as well as the steps listed
> > from the local MS4W page (#mapcache-apache-module).
> > I think I understand the basic principles and have added a new source
> > that looks like this:
> > <getmap>
> > <params>
> > <FORMAT>image/geotiff</FORMAT>
> > <TRANSPARENT>TRUE</TRANSPARENT>
> > <SRS>EPSG:4326</SRS>
> > <BBOX>-125,24,-61,49</BBOX>
> > </params>
> > </getmap>
> > <http>
> > <url>http://localhost:8080/wms <http://localhost:8080/wms></url>
> > </http>
> > </source>
> > and a new tileset that looks like this:
> > <tileset name="faa">
> > <source>faa</source>
> > <cache>disk</cache>
> > <grid>WGS84</grid>
> > <format>PNG</format>
> > <metatile>5 5</metatile>
> > <metabuffer>10</metabuffer>
> > <expires>3600</expires>
> > </tileset>
> > (This is the same as the "test" tileset with a different source.)
> > But how do I test this? The query
> http://localhost:8080/mapcache/wmts?service=wmts&request=getcapabilities&version=1.0.0
> > lists my new source as a layer. The docs say
> > 5.
> > Test your MapCache configuration by following steps in the
> > associated MapCache testing docs
> https://mapserver.org/mapcache/install.html#test-your-mapcache-module>
> > but that seems to be about testing the mapcache/demo. I don't see how
> > to add something to the mapcache/demo if that's possible. What am I
> > overlooking?
> > Thanks a lot,
> > carl
> > MapServer-users mailing list
> > MapServer-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20211025/8704b1ac/attachment-0001.html>
More information about the MapServer-users
