[mapserver-users] Float64 on WCS
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Wed Sep 8 06:26:41 PDT 2021
It seems to me that there is no support for Float64 anywhere in Mapserver. See IMAGEMODE in https://mapserver.org/mapfile/outputformat.html.
-Jukka Rahkonen-
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta CASTRO, Emmanuel via MapServer-users
Lähetetty: keskiviikko 8. syyskuuta 2021 15.45
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] Float64 on WCS
Hello
I am new to WCS. While testing WCS 2.0 mode on MapServer 2.18.
I noticed than WCS(1.0/2.0) only supports image mode BYTE, INT16 and FLOAT32 (I checked in the source mapwcs.cpp and mapwcs20.cpp). There is no support for FLOAT64.
Is there a specific reason for not supporting that? (GDAL supports FLOAT64 very well in GeoTiff).
My tests with WCS are from Grib2 data (Float64) to GeoTiff (which only produces Float32).
Thank you for your comments.
Emmanuel
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210908/3c521f1b/attachment.htm>
More information about the MapServer-users mailing list
