[mapserver-users] Raster Upsampling
Patrick Young
patrick.mckendree.young at gmail.com
Fri Sep 10 10:08:00 PDT 2021
As a quick follow up, a hack that worked to get around this was to make a
VRT of the low resolution dataset wherein I set the resampling to bilinear
in the VRT and set the resolution to much much higher, and that has the
desired effect. So the question is, is there a better way to achieve the
same thing in mapserver.
Thanks!
On Fri, Sep 10, 2021 at 10:17 AM Patrick Young <
patrick.mckendree.young at gmail.com> wrote:
> Hello!
> I was curious if it is possible to have mapserver bilinearly upsample a
> low resolution raster to a higher resolution when there is no reprojection
> required.
> My setup is that I have a very low resolution image (a bathymetric layer)
> and a much higher resolution image (aerial), both in web mercator. When I
> request a high resolution XYZ tile, the low resolution image remains
> pixelated (it looks as if its is nearest neighbor upsampled) at the
> raster's native resolution even though I have set in the PROCESSING
> directive RESAMPLE=BILINEAR.
> I suspect from the docs that RESAMPLE only comes into play when we're
> doing on-the-fly reprojection, is that correct? When no reprojection is
> required, but just simpler upsampling, can one change the kernel used?
> Many thanks!
> Patrick
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210910/4d711181/attachment.htm>
More information about the MapServer-users
