[mapserver-users] aking help about wms connection with mapserver
CASTRO, Emmanuel
emmanuel.castro at capgemini.com
Thu Sep 23 00:33:37 PDT 2021
Bonjour
Given the pathname of your path, it seems that your deployment is on Windows.
Maybe it is because you omitted the .exe suffix at the end of ‘…cgi-bin/mapserv?...’. Try ‘…cgi-bin/mapserv.exe?...’.
Double-check the map path too. It’s always a good idea to double-check.
Good luck
Emmanuel
De : MapServer-users <mapserver-users-bounces at lists.osgeo.org> De la part de Boubacar Bah
Envoyé : lundi 20 septembre 2021 02:38
À : mapserver-users at lists.osgeo.org
Objet : [mapserver-users] aking help about wms connection with mapserver
This mail has been sent from an external source
good evenin recently i created a mapfile which shoul use a wms server to display a map but oce that i run the url below in the browser:
http://localhost/cgi-bin/mapserv?map=C:/ms4w/Apache/htdocs/wms.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=country_bounds&STYLES=&SRS=EPSG:4326&BBOX=-173.537,35.8775,-11.9603,83.8009&WIDTH=400&HEIGHT=300&FORMAT=image/png
they send me an error below:
The requested URL was not found on this server.
this is my layer below :
LAYER
NAME modis_nasa
TYPE RASTER
OFFSITE 0 0 0
STATUS OFF
CONNECTIONTYPE WMS
CONNECTION "https://neo.sci.gsfc.nasa.gov/wms/wms?"
METADATA
"wms_srs" "EPSG:4326"
"wms_name" "MOD_143D_RR"
"wms_server_version" "1.1.1"
"wms_format" "image/jpeg"
END
PROJECTION
"init=EPSG:4326"
END
END
now i want to know how to fix this problem
thanks
This message contains information that may be privileged or confidential and is the property of the Capgemini Group. It is intended only for the person to whom it is addressed. If you are not the intended recipient, you are not authorized to read, print, retain, copy, disseminate, distribute, or use this message or any part thereof. If you receive this message in error, please notify the sender immediately and delete all copies of this message.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210923/7e00a3e9/attachment.html>
More information about the MapServer-users
