[mapserver-users] asking help about importing gdal librarie in apache python
Boubacar Bah
bahbouba.909 at gmail.com
Mon Sep 27 07:28:50 PDT 2021
Thanks a lot!
Le lun. 27 sept. 2021 à 15:16, CASTRO, Emmanuel <
emmanuel.castro at capgemini.com> a écrit :
> I seldom use MS4W. On Windows I’d rather use Conda Python distribution
> which comes with GDAL binding for Python (cf.
> https://gdal.org/download.html#windows).
> However four you MS4W installation, you can test this, from the MS4W doc :
> https://www.ms4w.com/README_INSTALL.html#gdal-bindings
> I think that you are missing an environment variable; maybe you should put
> the GDAL DLL explicitly in the PATH.
> Good luck
> Emmanuel
> *De :* MapServer-users <mapserver-users-bounces at lists.osgeo.org> *De la
> part de* Boubacar Bah
> *Envoyé :* samedi 25 septembre 2021 17:50
> *À :* mapserver-users at lists.osgeo.org
> *Objet :* [mapserver-users] asking help about importing gdal librarie in
> apache python
> This mail has been sent from an external source
> hello everyone ; i work with mapserver apache ; now i want to work with
> gdal library if l try to import the gdal this in python they send me an
> error this is the error message below:
> *>>> from osgeo import gdal Traceback (most recent call last): File
> "<stdin>", line 1, in <module> File
> "c:\ms4w\Python\lib\site-packages\osgeo\__init__.py", line 21, in <module>
> _gdal = swig_import_helper() File
> "c:\ms4w\Python\lib\site-packages\osgeo\__init__.py", line 17, in
> swig_import_helper _mod = imp.load_module('_gdal', fp, pathname,
> description) File "c:\ms4w\Python\lib\imp.py", line 242, in load_module
> return load_dynamic(name, filename, file) File
> "c:\ms4w\Python\lib\imp.py", line 342, in load_dynamic return
> _load(spec) ImportError: DLL load failed while importing _gdal: Le module
> spécifié est introuvable.*
> if someone can fix this l will please.
> thank advance.
> This message contains information that may be privileged or confidential
> and is the property of the Capgemini Group. It is intended only for the
> person to whom it is addressed. If you are not the intended recipient, you
> are not authorized to read, print, retain, copy, disseminate, distribute,
> or use this message or any part thereof. If you receive this message in
> error, please notify the sender immediately and delete all copies of this
> message.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20210927/35fd61b9/attachment-0001.html>
More information about the MapServer-users
