[mapserver-users] mapcache behind nginx with ssl
Trygve Aspenes trygve at aspenes.priv.no
Mon Sep 27 13:40:28 PDT 2021
Hi there
I have put up a mapserver behind nginx with ssl and a curl like this
curl -s
"https://mapserver/cgi-bin/mapserv?map=/data/mapserver/map-files/mapserver-8505ad3e-f9e3-4de3-a080-8253443ac954-20210908T120432Z.map&service=WMS&request=GetCapabilities"
| grep OnlineResource
Gives me like:
  <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
xlink:href="https://mapserver/cgi-bin/mapserv?map=/data/mapserver/map-files/mapserver-8505ad3e-f9e3-4de3-a080-8253443ac954-20210908T120432Z.map&"/>
           <Get><OnlineResource
xlink:href="https://mapserver/cgi-bin/mapserv?map=/data/mapserver/map-files/mapserver-8505ad3e-f9e3-4de3-a080-8253443ac954-20210908T120432Z.map&"/></Get>
           <Post><OnlineResource
xlink:href="https://mapserver/cgi-bin/mapserv?map=/data/mapserver/map-files/mapserver-8505ad3e-f9e3-4de3-a080-8253443ac954-20210908T120432Z.map&"/></Post>
Yeah you get the idea. Everything perfect with https in the href link.
Thanks!
So I put up a mapcache which I intend to put up i front of mapserver.
When I do a similar curl like:
curl -s
"https://mapcache/mapcache?Overview&map=/data/mapserver/map-files/mapserver-8505ad3e-f9e3-4de3-a080-8253443ac954-20210908T120432Z.map&SERVICE=WMS&REQUEST=GetCapabilities"
| xmllint --format - | grep OnlineResource
I get:
xlink:href="http://mapcache:8090/mapcache?"/>
I here starts the problems. If I do this in eg QGIS, QGIS are told to go
to the http address with port 8090(mapcache is setup to run on port 8090
behind the scenes) which is not reachable. It should return https (with
no specified port, ie. using standard https port) if I understands
correctly.
And I just cant figure put why.
The configuration for the two are almost identical and I have double and
tripple check my config.
Any idea what I should check next?
If it could be of any help I could open access to my mapcache server
running.
Thanks
Trygve
PS: when I test mapcache and mapserver setup locally without ssl and
nginx in front it works fine.
More information about the MapServer-users mailing list
