[mapserver-users] Floating point exception
Luca Delucchi lucadeluge at gmail.com
Fri Apr 8 05:13:07 PDT 2022
On Fri, 8 Apr 2022 at 11:03, Rahkonen Jukka (MML)
<jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Mapserver 8 has increased security and requires a special config file. The best link for the documentation at the moment is probably  https://mapserver.org/development/rfc/ms-rfc-135.html (The message "See mapserver.org/config_file.html for more information" points to non-existing location).
thanks I was think this is needed only for web request not to test a mapfile
> Why did you select "Floating point exception" as the title of your message?
because my starting problem (using mapserver 7) is this one...
> -Jukka Rahkonen-
ciao
Luca
www.lucadelu.org
More information about the MapServer-users mailing list
