[mapserver-users] Floating point exception
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Fri Apr 8 02:03:10 PDT 2022
Mapserver 8 has increased security and requires a special config file. The best link for the documentation at the moment is probably  https://mapserver.org/development/rfc/ms-rfc-135.html (The message "See mapserver.org/config_file.html for more information" points to non-existing location).
Why did you select "Floating point exception" as the title of your message?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Luca Delucchi
Lähetetty: perjantai 8. huhtikuuta 2022 11.39
Vastaanottaja: Jeff McKenna <jmckenna at gatewaygeomatics.com>
Kopio: MapServer <mapserver-users at lists.osgeo.org>
Aihe: Re: [mapserver-users] Floating point exception
I compiled the github master version and used map2img, the output is not helping so much...
map2img -m eurodeer_new.map -o eurodeer.png -all_debug 5 Cannot open configuration file /usr/local/etc/mapserver.conf.
msLoadConfig(): Unable to access file. See mapserver.org/config_file.html for more information.
msDrawMap(): Image handling error. Failed to draw layer named 'Research groups'. <br>
msPostGISLayerWhichShapes(): Query error. Failed to build query SQL. <br>
msPostGISBuildSQL(): General error message. Failed to build SQL 'where'. <br>
msSearchDiskTree(): Search returned no results. Unable to open spatial index for /home/lucadelu/github/euromammals/print_maps/././data/ne_10m_admin_0_sovereignty.qix.
In most cases you can safely ignore this message, otherwise check file names and permissions. <br>
msLoadConfig(): Unable to access file. See mapserver.org/config_file.html for more information. <br>
the 'Research groups' layer is defined like this
DATA "geom from (select research_groups_id, short_name, geom from main.research_groups where ST_Contains(!BOX!, geom)) as subquery using unique research_groups_id using srid=4326"
ciao
Luca
www.lucadelu.org
MapServer-users mailing list
MapServer-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
