[mapserver-users] Floating point exception
Luca Delucchi lucadeluge at gmail.com
Fri Apr 8 05:49:26 PDT 2022
On Fri, 8 Apr 2022 at 13:43, Jeff McKenna <jmckenna at gatewaygeomatics.com> wrote:
> Ciao Luca,
Ciao,
> I am wondering also if you tried to access the PostGIS data through
> ogrinfo yet (to confirm there is no data issue).  Note that I'd
> recommend GDAL 3.4.2, PROJ 8.2.1 with MapServer-main.
>   ogrinfo -ro PG:"user=xxxx password=xxxx host=127.0.0.1 port=5432
> dbname=xxxx" table -summary
yes this works
> Then, follow along the debugging document (
> https://www.mapserver.org/optimization/debugging.html ) and add the
> following inside your MAP object in mapfile:
>    CONFIG "CPL_DEBUG" "ON"
>    CONFIG "CPL_TIMESTAMP" "ON"
>    CONFIG "PROJ_DEBUG" "ON"
> Then re-retry map2img with -all_debug 5, and look for the full SELECT
> query made to your database, and run that same query inside psql
> commandline.
using map2img as suggested by Even  I got this
Reading symbols from map2img...
(gdb) run
Starting program: /home/lucadelu/installati/bin/map2img -m
eurodeer_new.map -o eurodeer.png -all_debug 5 -conf mapserver.conf
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
[New Thread 0x7fffebf54700 (LWP 801419)]
[New Thread 0x7fffeb753700 (LWP 801420)]
msDrawMap(): Image handling error. Failed to draw layer named 'Reserch
groups'. <br>
msPostGISLayerWhichShapes(): Query error. Failed to build query SQL. <br>
msPostGISBuildSQL(): General error message. Failed to build SQL 'where'. <br>
msSearchDiskTree(): Search returned no results. Unable to open spatial
index for /home/lucadelu/github/euromammals/print_maps/././data/ne_10m_admin_0_sovereignty.qix.
In most cases you can safely ignore this message, otherwise check file
names and permissions. <br>
[Fri Apr  8 14:38:55 2022].491539: GDAL: In GDALDestroy - unloading
GDAL shared library.
[Thread 0x7fffebf54700 (LWP 801419) exited]
[Thread 0x7fffec613bc0 (LWP 801411) exited]
[Inferior 1 (process 801411) exited with code 01]
However using shp2img with a running map file I was able to get the
full postgis query and run it on a database returning the error
"Floating point exception" without any problem.
select "short_name"::text,ST_AsBinary(("geom"),'NDR') as
geom,"research_groups_id"::text from (select research_groups_id,
short_name, geom from main.research_groups where
ST_Contains(ST_GeomFromText('POLYGON((-15.2587587587588
35,-15.2587587587588 70,37.2587587587588 70,37.2587587587588
35,-15.2587587587588 35))',4326), geom)) as subquery
> -jeff
ciao
Luca
www.lucadelu.org
More information about the MapServer-users mailing list
