[MapServer-users] Content of WMS based on attribute
Bjørn Ove Grøtan bjorn.ove at grotan.com
Fri Aug 19 08:06:56 PDT 2022
You can also use Dimensions: https://mapserver.org/ogc/wms_dimension.html#enabling-dimension-support-in-mapserver
Which is supported outside vendor specific parameters.
Dimensions can be e.g. a codelist of values (text), and not just time or elevation dimension.
Dimensions will be reflected in GetCapabilities-document, so you can build your user interface on top of that.
-Bjørn Ove
Jörg Thomsen (WhereGroup):
> Hello Marcin,
> no problem, you can achieve this with vendor specific parameters and
> run-time-substitution:
> https://mapserver.org/cgi/runsub.html
> Jörg
> Am 19.08.22 um 14:30 schrieb Marcin Niemyjski via MapServer-users:
> > Hello,
> > I am wondering if it is possible to modify the GetMap request so that it
> > displays elements of the Postgresql database based on the value of their
> > attributes, e.g., having a set of polygons representing fields by
> > writing crop = sunflower in the GetMap request, the polygons
> > representing that crop will be returned.
> > Thanks,
> > Marcin
> > MapServer-users mailing list
> > MapServer-users at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/mapserver-users
> Viele Grüße,
> Jörg Thomsen
> Aufwind durch Wissen!
> Jetzt neu: Web-Seminare und Online-Schulungen
> bei der www.foss-academy.com
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Tel: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> joerg.thomsen at wheregroup.com
> www.wheregroup.com
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
More information about the MapServer-users mailing list
