[MapServer-users] Mapserver 8 rc1
Scott public at postholer.com
Thu Aug 25 15:01:55 PDT 2022
Thank you for the quick response and all that you folks do!
On 8/25/22 14:54, Steve Lime wrote:
> Thanks for checking! Looks like there might be an issue with
> the msPostGISReplaceBoxToken() rewrite in C++ in mappostgis.cpp.
> On Thu, Aug 25, 2022 at 4:20 PM Scott <public at postholer.com
> <mailto:public at postholer.com>> wrote:
>     ms_error log is telling me it's unable to build the SQL query. There
>     are
>     no errors in the postgresql log.
>     Even if I comment the line out I get an error, such as:
>     --where st_intersects(geom, !BOX!)
>     or:
>     /* !BOX! */
>     If it exists any where in the DATA block, it fails.
>     Here's the ms error log:
>     [Thu Aug 25 13:46:55 2022].451955 msPostGISBuildSQL(): General error
>     message. Failed to build SQL 'where'.
>     [Thu Aug 25 13:46:55 2022].451980 msPostGISLayerWhichShapes(): Query
>     error. Failed to build query SQL.
>     [Thu Aug 25 13:46:55 2022].452010 msDrawMap(): Image handling error.
>     Failed to draw layer named 'wptByTrailType'.
>     On 8/25/22 13:03, Steve Lime wrote:
>      > Hmmm... Wasn't an intentional omission. If you have logging
>     turned on
>      > and can see the resulting SQL, does the !BOX! get replaced but just
>      > incorrectly or is the !BOX! still in the SQL.
More information about the MapServer-users mailing list
