[MapServer-users] [EXTERNAL] Vector tileindex with connectiontype OGR
Even Rouault even.rouault at spatialys.com
Thu Dec 8 08:08:25 PST 2022
Pete,
actually this is documented in
https://mapserver.org/input/vector/ogr.html#tileindex-with-ogr and
tested in
https://github.com/MapServer/MapServer/blob/1a45e6074b71738e576563ac39f60fd96ded50eb/msautotest/wxs/wfs_ogr_tileindexmixedsrs.map
So for a OGR vector layer, the value of TILEINDEX must be a shapefile or
a OGR datasource name, not a MapServer layer, contrary to raster support
(contour layers use raster logic underneath).
Even
Le 08/12/2022 à 16:44, Peter Schmitt a écrit :
> On Thu, Dec 8, 2022 at 12:55 AM Rahkonen Jukka
> <jukka.rahkonen at maanmittauslaitos.fi> wrote:
>     We are using the ”layer-as-a-tileindex” method right now with a
>     bit older Mapserver version and with native POSTGIS connection
>     type. In the orthophoto layer we use
>     I hope that this still works with Mapserver 8. It would be nice if
>     you could make a test and compare OGR vs POSTGIS connection types.
> This test is the closest I could find of ”layer-as-a-tileindex of
> vectors" that makes me think it should work:
> https://github.com/MapServer/MapServer/blob/1a45e6074b71738e576563ac39f60fd96ded50eb/msautotest/wxs/contour_tileindex.map#L70-L101
> What version of MapServer are you using?
> Can you try this mapfile on your version of Mapserver?
> ### tindex.geojson
> "type":"FeatureCollection","features":[{"type":"Feature","properties":{"location":"/app/mapfiles/test.geojson"},"geometry":{"type":"Polygon","coordinates":[[[122.013774753,29.96355712],[122.014247522,29.915620561],[122.06927508,29.916020438],[122.068828693,29.963957768],[122.013774753,29.96355712]]]}}]}
> ### test.geojson
> {"type":"Feature","properties":{},"geometry":{"coordinates":[[[122.04067791363536,29.944772490597998],[122.03620089848994,29.94141730774004],[122.03819740524398,29.937852301951125],[122.0446709271447,29.938166866424368],[122.04648593328471,29.940211511256464],[122.04067791363536,29.944772490597998]]],"type":"Polygon"}}
> ### test2.map
> MAP
>   OUTPUTFORMAT
>     NAME "geojson"
>     DRIVER "OGR/GEOJSON"
>     MIMETYPE "application/json; subtype=geojson"
>     FORMATOPTION "STORAGE=memory"
>     FORMATOPTION "FORM=SIMPLE"
>     FORMATOPTION "LCO:RFC7946=NO"
>     FORMATOPTION "FILENAME=result.json"
>   END
>   WEB
>     METADATA
>       "ows_enable_request"              "*"
>       "wfs_getfeature_formatlist"       "ogrgml,geojson"
>     END
>   END
>   CONFIG "MS_ERRORFILE" "stderr"
>   PROJECTION
>     "init=epsg:4326"
>   END
>   # mapserv -nh
> QUERY_STRING='service=WFS&VERSION=1.0.0&REQUEST=getfeature&map=/app/mapfiles/test2.map&typename=vector_directly&OUTPUTFORMAT=geojson'
>   # returns the contents of 'test.geojson'!
>   LAYER
>     NAME "vector_directly"
>     TYPE POLYGON
>     TILEINDEX "/app/mapfiles/tindex.geojson"
>     CONNECTIONTYPE OGR
>     STATUS OFF
>   END
>   # mapserv -nh
> QUERY_STRING='service=WFS&VERSION=1.0.0&REQUEST=getfeature&map=/app/mapfiles/test2.map&typename=tindex_ogr&OUTPUTFORMAT=geojson'
>   # returns contents of tindex.geojson!
>   LAYER
>     DEBUG 5
>     NAME "tindex_ogr"
>     TYPE POLYGON
>     CONNECTIONTYPE OGR
>     CONNECTION "/app/mapfiles/tindex.geojson"
>     STATUS OFF
>   END
>   # mapserv -nh
> QUERY_STRING='service=WFS&VERSION=1.0.0&REQUEST=getfeature&map=/app/mapfiles/test2.map&typename=vector_tindex&OUTPUTFORMAT=geojson'
>   # returns 'msTiledSHPOpenFile(): Shapefile error. Tileindex layer
> must be a shapefile.'
>   LAYER
>     NAME "vector_via_tindex"
>     TYPE POLYGON
>     TILEINDEX tindex_ogr
>     STATUS OFF
>   END
>   #  mapserv -nh
> QUERY_STRING='service=WFS&VERSION=1.0.0&REQUEST=getfeature&map=/app/mapfiles/test2.map&typename=vector_via_ogr&OUTPUTFORMAT=geojson'
>   # returns 'msOGRFileOpen(): OGR error. Open failed for OGR
> connection in layer `vector_via_ogr'.  File not found or
> unsupported format. Check server logs.'
>     LAYER
>         DEBUG 5
>         NAME "vector_via_ogr"
>         TYPE POLYGON
>         CONNECTIONTYPE OGR
>         STATUS OFF
>     END
> END # mapfile
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221208/ec414354/attachment.htm>
More information about the MapServer-users mailing list
