[MapServer-users] [EXTERNAL] Vector tileindex with connectiontype OGR
Rahkonen Jukka
jukka.rahkonen at maanmittauslaitos.fi
Wed Dec 7 11:18:41 PST 2022
I made some tests and noticed that the OGR tileindex does not need to be a shapefile but GeoPackage worked as well. Actully what did not work was to make a vector layer from tileindex that was saved into GeoPackage and to use that layer in TILEINDEX. And then I noticed that this behavior is documented in https://www.mapserver.org/input/vector/ogr.html#tileindex-with-ogr:
"OGR layers can utilize tile indexes in a similar fashion to Shapefile based layers. The TILEINDEX keyword should contain the connection string for the tile index file. The tile index file may be any supported OGR format, including shapefiles."
So this is what I used in LAYER and it worked both for WMS and WFS:
CONNECTIONTYPE OGR
TILEINDEX "c:\data\000\mapservertest\tindex.gpkg"
I do not know when and if this behavior has changed. I thought as well that the layer-as-a-tileindex would be the way to follow if tileindex is not in shapefile format.
-Jukka Rahkonen-
Lähettäjä: MapServer-users <mapserver-users-bounces at lists.osgeo.org> Puolesta Peter Schmitt
Lähetetty: keskiviikko 7. joulukuuta 2022 19.08
Vastaanottaja: Schylberg Lars <lars.schylberg at saabgroup.com>
Kopio: Mapserver-Users (mapserver-users at lists.osgeo.org) <mapserver-users at lists.osgeo.org>
Aihe: Re: [MapServer-users] [EXTERNAL] Vector tileindex with connectiontype OGR
On Wed, Dec 7, 2022 at 1:16 AM Schylberg Lars <lars.schylberg at saabgroup.com<mailto:lars.schylberg at saabgroup.com>> wrote:
> The important thing is to have a one layer for the actual tile index, that has status off and one layer that is using the tile index layer.
Thanks for the message, Lars! This gave me another idea to debug.
When I set DEBUG 5 and request
mapserv -nh QUERY_STRING='service=WFS&VERSION=1.0.0&REQUEST=getfeature&map=/app/mapfiles/test2.map&typename=vector_via_ogr&OUTPUTFORMAT=geojson'
then the log contains
OGROPen(tindex_ogr)
msOGRFileOpen(): OGR error. Open failed for OGR connection in layer `vector_via_ogr'. File not found or unsupported format. Check server logs.
with the layers
LAYER
DEBUG 5
NAME "tindex_ogr"
TYPE POLYGON
CONNECTIONTYPE OGR
CONNECTION "/app/mapfiles/tindex.geojson"
STATUS OFF
END
LAYER
DEBUG 5
NAME "vector_via_ogr"
TYPE POLYGON
TILEINDEX tindex_ogr
CONNECTIONTYPE OGR
STATUS OFF
END
This log line
OGROPen(tindex_ogr)
makes me suspect the following lines of code are setting the OGR dataset name to "tindex_ogr", whereas I expect it to do something like use the value from CONNECTION in the layer with name "tindex_ogr".
https://github.com/MapServer/MapServer/blob/71ecf4028b0769027df3a970a36d56feb1d46ab6/mapogr.cpp#L1205-L1238<https://eur06.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgithub.com%2FMapServer%2FMapServer%2Fblob%2F71ecf4028b0769027df3a970a36d56feb1d46ab6%2Fmapogr.cpp%23L1205-L1238&data=05%7C01%7Cjukka.rahkonen%40maanmittauslaitos.fi%7C6cce5ce3dc674b610d1608dad875a01d%7Cc4f8a63255804a1c92371d5a571b71fa%7C0%7C0%7C638060296970211320%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=3bCVBIt9JxfoIArjTPKTM4AREHBzvW5iq%2Fev8XsfZJw%3D&reserved=0>
In other words, I expect the log line to read
OGROPen(/app/mapfiles/tindex.geojson)
and not
OGROPen(tindex_ogr)
This seems to be unique for a vector tile index of vectors. This otherwise works fine when using a vector tileindex of rasters. So if I make a bogus raster layer like
LAYER
DEBUG 5
NAME "bogus_raster"
TYPE RASTER
STATUS OFF
PROJECTION
"init=epsg:3857"
END
END
and then issue a bogus request like
curl 'http://localhost:8000/wms?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&FORMAT=image/png&TRANSPARENT=true&map=/app/mapfiles/test2.map&layers=bogus_raster&WIDTH=256&HEIGHT=256&CRS=EPSG:3857&STYLES=&BBOX=4163066.308523841,5943743.319455305,4167958.2783340923,5948635.289265556'
Then the log line includes
msOGRFileOpen(/app/mapfiles/tindex.geojson)...
msConnPoolRegister(tindex_ogr,/app/mapfiles/tindex.geojson,0x556aba222630)
and _not_
msOGRFileOpen(tindex_ogr)...
like I see for a vector tile index of vectors.
Thanks, Pete
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221207/8702e272/attachment-0001.htm>
More information about the MapServer-users
