[MapServer-users] Setting up Mapserver 8 on Windows
Kalbermatten Michaël
Michael.Kalbermatten at ne.ch
Mon Dec 12 06:22:26 PST 2022
Hi everbody,
I just spend a couple of hours trying to set up Mapserver 8.0 on Windows. To do that, I downloaded the latest stable release from GisInternals.
I am using Apache and FastCGI as webserver.
Everything went smoothly until I tried to make Mapserver load the new needed configuration file. It was just always claiming that it couln't load this file ("msLoadConfig(): Unable to access file."), but I had set "SetEnv MAPSERVER_CONFIG_FILE" in my Apache configuration. Even setting MAPSERVER_CONFIG_FILE in a global system variable did not solve the issue.
After quite a while, I found this issue on Mapserver's issue tracker: https://github.com/MapServer/MapServer/issues/6411
This had not a lot to do with my issue, but I discovered the existence of FcgidInitialEnv. Setting this variable (FcgidInitialEnv MAPSERVER_CONFIG_FILE "C:/whereever/mapserver.conf") solved the issue.
So, is it mandatory to set FcgidInitialEnv when using Mapserver with FastCGI? If yes, wouldn't it be good to add something to the documentation (https://mapserver.org/mapfile/config.html).
Moreover, I spied in the ms4w 5 package. It seemed to me that they were using FastCGI as well, but I could not find anything regarding FcgidInitialEnv, thus my question...
Thanks a lot to anyone who would have some information regarding that.
Best regards
Michael
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221212/c4b1089a/attachment.htm>
More information about the MapServer-users
