[MapServer-users] Tileindex in format different than SHP?
Marcin Niemyjski mniemyjski at cloudferro.com
Wed Dec 14 05:07:47 PST 2022
Jeff,
I checked TILEINDEX documentation before writing to you. I found no information's about other formats except that shapefile is usually used.
Jukka,
I created an extra layer as you suggested, thanks - it works, but I will stay with Shapefiles on this one. When working with tileindex as extra layer it takes 2x more time for mapserver to render the layer.
Thank you all,
Marcin
From: MapServer-users <mapserver-users-bounces at lists.osgeo.org> on behalf of Jeff McKenna <jmckenna at gatewaygeomatics.com>
Sent: Wednesday, December 14, 2022 1:51 PM
To: mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
Subject: Re: [MapServer-users] Tileindex in format different than SHP?
I had recently spent a few weeks of effort on updating the documentation
for TILEINDEX, with many examples, see :
https://mapserver.org/optimization/tileindex.html
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training
co-founder of FOSS4G
http://gatewaygeo.com/
On 2022-12-14 7:23 a.m., Marcin Niemyjski via MapServer-users wrote:
> Hello,
> Can I use format different than SHP while using tileindex of rasters?
> When using Mapfile with configuration as below:
> LAYER
>              NAME "2021-01-02_high"
>          STATUS ON
>          TILEINDEX "/DyskPlanetiler/Sentinel1COG/2021/01/02/2021-01-02.gpkg"
>          TILEITEM "location"
>          TYPE RASTER
>          MAXSCALEDENOM 4000000
>          GROUP "2021-01-02"
>          PROJECTION
>              "init=epsg:4326"
>          END
> END
> error is recived:
> msShapefileOpen(): Unable to access file.
> (/DyskPlanetiler/Sentinel1COG/2021/01/01/2021-01-01.gpkg)
> is there a way to use geopackage or flatgeobuf as indexes or do I have
> to go back to shp?
> Best,
> Marcin
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221214/a76ffbe5/attachment.htm>
More information about the MapServer-users mailing list
