[MapServer-users] Link in SLD doc returns an exception
Brent Fraser bfraser at geoanalytic.com
Fri Dec 30 14:34:06 PST 2022
Hi All,
I'm experimenting with SLD and reading the MapServer doc.  On the SLD page under Server Side Support, it says "Test the remote SLD request" with a link to
https://demo.mapserver.org/cgi-bin/wms?SERVICE=wms&VERSION=1.1.1&REQUEST=GetMap&LAYERS=country_bounds&FORMAT=png&WIDTH=400&HEIGHT=300&SRS=EPSG:4326&STYLES=&BBOX=-180.0,-90.0,180.0,90.0&TRANSPARENT=TRUE&SLD=https://demo.mapserver.org/ogc-demos/map/sld/sld_line_simple.xml
The link looks good but it returns an exception:
<?xml version='1.0' encoding="UTF-8" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msSLDApplySLDURL: WMS server error. Could not open SLD https://demo.mapserver.org/ogc-demos/map/sld/sld_line_simple.xml and save it in a temporary file. Please make sure that the sld url is valid and that the temporary path is set. The temporary path can be defined for example by setting TEMPPATH in the map file. Please check the MapServer documentation on temporary path settings.
msHTTPExecuteRequests(): HTTP request error. HTTP GET request failed with status 404 () for https://demo.mapserver.org/ogc-demos/map/sld/sld_line_simple.xml
</ServiceException>
</ServiceExceptionReport>
Is the demo in a repo somewhere or does someone have some insight?  Thanks!
Best regards,
Brent Fraser
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20221230/1a1df204/attachment.htm>
More information about the MapServer-users mailing list
