[mapserver-users] mapserv cli and run-time substitution
andy
aborruso at gmail.com
Sat Feb 5 09:13:33 PST 2022
I have this map file [1] in which I use this simple class expression
"EXPRESSION ([year] < 1976)".
Starting from it, I'm able to create the png output I want, running:
But if I replace the hard coded year value with '%year%', and then I run
this command
I have a wrong PNG output, in which the layer that has the run-time
substitution variable is not rendered properly, because it seems that the
value is not collected.
What's wrong with my steps? How to use run-time substitution via cli?
Thank you,
Andrea
[1] https://gist.github.com/aborruso/f40da26ec0cb9daa8cb7b308189ce3b3
___________________
Andrea Borruso
website: https://medium.com/tantotanto
38° 7' 48" N, 13° 21' 9" E, EPSG:4326
___________________
"cercare e saper riconoscere chi e cosa,
in mezzo all’inferno, non è inferno,
e farlo durare, e dargli spazio"
Italo Calvino
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220205/4677661c/attachment.htm>
More information about the MapServer-users
