[mapserver-users] mapserv cli and run-time substitution
Seth G sethg at geographika.co.uk
Sun Feb 6 00:34:56 PST 2022
Shouldn't the variable be wrapped in percentage signs?
EXPRESSION (%year% < 1976)
Seth
web:http://geographika.net
twitter: @geographika
On Sat, Feb 5, 2022, at 6:13 PM, andy wrote:
> Hi,
> I have this map file [1] in which I use this simple class expression "EXPRESSION ([year] < 1976)".
> Starting from it, I'm able to create the png output I want, running:
> But if I replace the hard coded year value with '%year%', and then I run this command
> I have a wrong PNG output, in which the layer that has the run-time substitution variable is not rendered properly, because it seems that the value is not collected.
> What's wrong with my steps? How to use run-time substitution via cli?
> Thank you,
> Andrea
> [1] https://gist.github.com/aborruso/f40da26ec0cb9daa8cb7b308189ce3b3
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
>  in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220206/8741bddd/attachment.htm>
More information about the MapServer-users mailing list
