[mapserver-users] mapserv cli and run-time substitution
Seth G
sethg at geographika.co.uk
Sun Feb 6 01:08:26 PST 2022
Ah ok I was looking at the mapfile. Passing &YEAR=1976 in from the command line should work fine.
Maybe the value is being treated as a string, so you could test if the following worked (equals rather than less than):
EXPRESSION ("[year]" = "%year%")
Also maybe try with a different parameter name e.g. MYYEAR just in case YEAR is treated differently as it is used for various OGC services.
Seth
web:https://geographika.net
twitter: @geographika
On Sun, Feb 6, 2022, at 9:50 AM, andy wrote:
> Hi Seth,
> On Sun, 6 Feb 2022 at 09:35, Seth G <sethg at geographika.co.uk> wrote:
>> Shouldn't the variable be wrapped in percentage signs?
>> EXPRESSION (%year% < 1976)
> my goal is another one. My hardcorded expression is "EXPRESSION ([year] < 1976)".
> I want to use run-time substitution to use "EXPRESSION ([year] < '%year%')", in the same way described here:
> https://mapserver.org/el/mapfile/validation.html#test-with-commandline
> Thank you
> ___________________
> Andrea Borruso
> website: https://medium.com/tantotanto
> 38° 7' 48" N, 13° 21' 9" E, EPSG:4326
> ___________________
> "cercare e saper riconoscere chi e cosa,
> in mezzo all’inferno, non è inferno,
> e farlo durare, e dargli spazio"
> Italo Calvino
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220206/f6a99b85/attachment.htm>
More information about the MapServer-users
