[mapserver-users] Mapcache disk cache gives unexpected paths to tiles
Trygve Aspenes
trygve at aspenes.priv.no
Wed Feb 9 07:10:55 PST 2022
Ah, thanks Thomas!
I did not catch that from the documentation.
I also needed to add layout like this:
<cache name="disk" type="disk" layout="template">
<template>/mapcache/{tileset}/{grid}/{dim:time}/{z}/{x}/{y}.{ext}</template>
</cache>
to make it work ( both from testing and looking at the documentation)
If you use the default this will be like tilecache as far as I
understand.
Do you have any idea what will be the fastest? To use default like:
<cache name="disk2" type="disk">
<base>/mapcache</base>
</cache>
or the solution above with template? ( As a lot of 000 directories will
be created with the base one)
Trygve
Den 2022-02-09 12:24, skrev thomas bonfort:
> You should remove the <base>/mapcache</base> from the >cache> block,
> as it takes precedence over your <template>
> thomas
> On Wed, Feb 9, 2022 at 12:10 PM Trygve Aspenes
> <trygve at aspenes.priv.no> wrote:
>> Hi
>> I have a mapcache running using disk as cache method with config
>> like
>> this:
>> <cache name="disk" type="disk">
> <template>/mapcache/{tileset}#{grid}#{dim}/{z}/{x}/{y}.{ext}</template>
>> </cache>
>> But here is what I get on disk:
>> /mapcache/<my tileset
>> name>/EPSG:3857/2022-02-05T00:12:00Z/05/000/000/038/000/000/043.png
>> What I don't understand is below the zoom level (here 05) I get 000
>> followed by 000. Then the y followed by another double 000 before I
>> get
>> the x with my extension.
>> Where does all these 000 sub directories comes from and what
>> functions
>> do they have?
>> I don't think this affects the performance, but this must cause
>> creating
>> thousands and thousands of unnecessary sub directories?
>> Thanks.
>> Trygve
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
