[mapserver-users] How to limit the width of the outline when the symbol size changes with the map scale?
Kyle Qian
kyleqian at gmail.com
Fri Feb 25 15:57:55 PST 2022
The map file I used is:
CLASS
NAME "Populated Places"
STYLE
SYMBOL "PT-1"
COLOR "#00A2E8"
OPACITY 100
MINSIZE 10
MAXSIZE 30
SIZE 16.5
OFFSET 0 0
OUTLINECOLOR "#FF0000"
OUTLINEWIDTH 5
END
END
SYMBOLSCALEDENOM 68247.34668319309
SYMBOL
NAME "PT-1"
TYPE ellipse
FILLED true
POINTS 5 5 END
END
Kyle Qian <kyleqian at gmail.com> 于2022年2月26日周六 07:56写道:
> Hi, when I set up a map for points, I use SYMBOLSCALEDENOM to change
> the size of points and MIN/MAXSIZE to limit it, but there seems to be no
> way to control the width of the outline of points. The outline seems to
> keep getting bigger as the map zooms in. The image below is the result map
> as the map zooms in:
> https://pasteboard.co/JC19o7caYHHk.png
> Is there any way to solve this problem?
> In addition, it seems that there is no way to set the transparency of the
> outline separately. Is it necessary to use a separate STYLE to implement it
> with GEOMTRANSFORM?
> Thanks.
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220226/f4aa69bd/attachment-0001.html>
More information about the MapServer-users
