[mapserver-users] working with ESRI coordinate systems in proj.db
Mark Volz
MarkVolz at co.lyon.mn.us
Thu Jan 6 09:19:28 PST 2022
Hello,
Could someone help me with setting up mapserver to use a non ESRI projection that is already stored in proj.db? The coordinate system is for Lyon County, MN #103749 and is stored with ESRI as the authority. I know that we can set up Mapserver to use Web Mercator by setting the adding "init=epsg:4326" to a projection block. Unfortunately I cannot access my counties coordinate system by setting the projection with "init=esri:103749".
Thank you for any help!
Sincerely,
Mark Volz, GISP
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220106/bc9d116f/attachment.htm>
More information about the MapServer-users
