[mapserver-users] Mapcache time dimension default value; and 'tearing down pooled connection' message
David Hoese dhoese at gmail.com
Mon Jan 17 17:52:28 PST 2022
Trygve,
Hello from outside the Pytroll community ;)
I can't answer your second question as I don't have much experience with
getCapabilities, but I think I have an answer for the first question. My
understanding for the `default` parameter was that that was the returned
time string if no times were returned by the query (empty result). I
have always expected this to be a normal time string like
2022-01-01T12:00:00Z (to match your expected format. However, the fact
that you always get the oldest image when the default is "d1" is
surprising to me so I hope the mapcache devs can correct me.
As for the source code for this, I found that the default from the XML
goes into a dimension object as "default_value". It then gets set as the
default "requested_value" like here:
https://github.com/MapServer/mapcache/blob/447c0c6848fd101c11e6d54e451037e571117ef1/lib/tileset.c#L585
Going down the rabbit hole led me to here:
https://github.com/MapServer/mapcache/blob/447c0c6848fd101c11e6d54e451037e571117ef1/lib/dimension_pg.c#L265-L271
As far as I can tell "get_values_for_entry_query" is just the
"validate_query" query from your XML config. So somehow your validate
query with "dp1" input may be returning the oldest time in your
database. Just a guess. I'm interested in this answer, but definitely
not the best person to give it to you.
Dave
On 1/17/22 11:59, Trygve Aspenes wrote:
> Hi there!
> Slowly I'm getting mapserver/mapcache up running and looks now how to
> improve things.
> First: When I load a mapcache tileset with time dimension from a pg db
> the oldest image is displayed in my client. Is it possible to somehow
> get the newest image as default?
> My tileset dimension look something like this:
>              <dimension type="postgresql" name="time" default="d1"
> time="true" unit="ISO8601">
>                  <connection>
>                      host=mapserver-db user=$PGSQ_USERNAME
> password=$PGSQ_PASSWORD dbname=mapserver port=5432
>                  </connection>
>                  <list_query>SELECT to_char(time,
> 'YYYY-MM-DD"T"HH24:MI:SS"Z"') FROM products where product_name='<some
> product>' order by Id</list_query>
>                  <validate_query>
>                      SELECT to_char(time,'YYYY-MM-DD"T"HH24:MI:SS"Z"')
> FROM products
>                      WHERE time >= to_timestamp(:start_timestamp)
>                      AND time <= to_timestamp(:end_timestamp)
>                      AND product_name='<some product>'
>                      ORDER BY time DESC
>                  </validate_query>
>              </dimension>
> I saw the `d1` default value in the documentation, but don't understand
> of that is a dummy or an actual selector. I have grepped around the
> source code, but could not see anything obvious.
> Second: My client updates/fetch the getCapabilities of my mapcache
> server every minute. Each time this is fetched the mapcache log is
> filled with messages like:
> mod_mapcache.c(164): [client ] tearing down pooled connection (dim_<some
> product>_time) to make room, referer: <my client>
> I dont understand why these connections is teared down every time
> getCapabilites is requested.
> I have looked in the documentation, but could not see how to control
> this. But in the mapcache.xml.sample the connection pool config is
> described. But adding this to my mapcache config does not remove these
> tear downs.
>      <connection_pool>
>          <max_connections>2000</max_connections>
>          <time_to_live_us>120000000</time_to_live_us>
>      </connection_pool>
> Any suggestions why this connection tear down is happening and if there
> is something to do about it. It slows down the getCapabilities request a
> bit, but if I add to many tileset I guess this will even further slow down.
> Thanks
> Trygve Aspenes
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
