[mapserver-users] Correct Mod Rewrite rule
Paul Lewis paul.lewis at igeotec.com
Mon Jun 13 02:28:02 PDT 2022
I Want to change this:
*https://<our
server>/cgi-bin/mapserv?map=/usr/share/mapserv/mapfile.map&service=wms&version=1.3.0&request=GetCapabilities*
To this:
*https://<our server>/wms?service=WMS&version=1.3.0&request=GetCapabilities*
So I've enabled apache2 mod-rewrite and created a .htaccess file with
the following rule as per Mapserver docs:
*RewriteEngine on**
**RewriteRule wms?(.*)
/cgi-bin/mapserv?map=/usr/share/mapserv/mapfile.map&$1**
I've also adapted this rule to numerous variations to try and get it
working but to no avail.
The first link returns xml as expected.
The second link returns this error:
*mapserv(): Web application error. Traditional BROWSE mode requires a
TEMPLATE in the WEB section, but none was provided.*
I've an error log running for the rewrite with an example trace as follows:
*[Thu Jun 09 18:54:22.033848 2022] [rewrite:trace3] [pid 40275:tid
140188000974592] mod_rewrite.c(483): [client <browser IP>:62351]
<browser IP> - - [<our
server>/sid#7f80151c0340][rid#7f80147130a0/initial] [perdir
/var/www/html/] strip per-dir prefix: /var/www/html/wms -> wms**
**[Thu Jun 09 18:54:22.033855 2022] [rewrite:trace3] [pid 40275:tid
/var/www/html/] applying pattern 'wms?(.*)' to uri 'wms'**
**[Thu Jun 09 18:54:22.033864 2022] [rewrite:trace2] [pid 40275:tid
/var/www/html/] rewrite 'wms' ->
'/cgi-bin/mapserv?map=/usr/share/mapserv/gni_wms.map&'**
**[Thu Jun 09 18:54:22.033870 2022] [rewrite:trace3] [pid 40275:tid
server>/sid#7f80151c0340][rid#7f80147130a0/initial] split
uri=/cgi-bin/mapserv?map=/usr/share/mapserv/gni_wms.map& ->
uri=/cgi-bin/mapserv, args=map=/usr/share/mapserv/gni_wms.map**
**[Thu Jun 09 18:54:22.033877 2022] [rewrite:trace2] [pid 40275:tid
/var/www/html/] trying to replace context docroot /var/www/html with
context prefix**
**[Thu Jun 09 18:54:22.033883 2022] [rewrite:trace1] [pid 40275:tid
/var/www/html/] internal redirect with /cgi-bin/mapserv [INTERNAL
REDIRECT]**
Am I correct in thinking that the redirect is not handling the GET params?
Which means my rule is wrong and is hence passing the wrong request
string to mapserver thus causing the error?
Paul
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220613/980f589b/attachment.htm>
More information about the MapServer-users mailing list
