[mapserver-users] Zoom into a query
roman villarreal romanvillarrealh at live.com.mx
Sat Mar 12 12:35:14 PST 2022
Hi to all
I wish all of you are ok, i have a problem and i hope some one of you can help me, for diferente reazons i was working with an old versión of mapserver (6.0.3) (i prommise update when finish this proyect)
I have a template file for a ITEMNQUERY result, the query sentence Works fine, and locate fine the object to search, but i can´t do a zoom into the query result, only select the object in the map.
How can i make a zoom into the resultant object.
This is the code of the template file:
Plantilla2.php
<!– MapServer Template –>
<html>
                <head>
                               <title>MEX - GIS</title>
                               <meta charset="UTF-8" />
                </head>
                <body>
                               <form method="GET" action="[program]" name="gis_elem">
                                               <strong>Localización individual de elementos en GIS</strong>
                                               <input type="hidden" name="program" value="[program]">
                                               <input type="hidden" name="map" value="[map]">
                                               <input type="hidden" name="imgxy" value="[center]">
                                               <input type="hidden" name="imgext" value="[mapext]">
                                               <input type="hidden" name="dato" value="[dato]">
                                               <input type="hidden" name="mode" value="ITEMNQUERY">
                                               <input type="hidden" name="qstring" value="[qstring]">
                                               <input type="hidden" name="qlayer" value="[qlayer]">
                                               <input type="hidden" name="qitem" value="[qitem]">
                                               <input type="hidden" name="slayer" value="[slayer]">
                                               <input type="hidden" name="mapx" value="[mapx]">
                                               <input type="hidden" name="mapy" value="[mapy]">
                                               <input type="hidden" name="id_ele" value="[id_ele]">
                                               <input type="hidden" name="elem" value="[elem]">
                                               <script>
                                                               var r;
                                                               r="[mode]";
                                                               if (r!="ITEMNQUERY"){document.forms["gis_elem"].submit();}
                                               </script>
                                               <table border="1">
                                                               <tr>
                                                               <td align="center"><input type="image" name="img" src="[img]" border="0"></td>
                                                               <td align="left" valign="top">
        <p><strong>El elemento se encuentra en el grupo de [elem]</strong></p>
        <p><strong>ID.Elemento:</strong> [id_ele]</p>
        <p> <strong>Nombre:</strong> [nm_pozo]</p>
        <hr size="1">
        <p> <strong>mensaje:</strong> [dato] </p>
                                                               </td>
                                                               <tr><td valign="middle">Escala: 1:[scale]</td></tr>
                                               </table>
                               </form>
                </body>
</html>
Really thanks for your answers, ideas and help
Regards
Román Villarreal
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20220312/def67fc9/attachment.htm>
More information about the MapServer-users mailing list
