[mapserver-users] Mapserver projection, auto and extent
Trygve Aspenes trygve at aspenes.priv.no
Thu May 19 23:52:32 PDT 2022
Thanks Jeff
I have used the build in network logger available in new versions of
QGIS ( I think you can activate it by pressing F12) a lot. That has been
essential for me to understand whats going on, especially when I was
debugging time dimension in some other setup.
I revisited the wms-server doc you suggested and from that I added UNITS
DD, and after that it seems to work. But the catch is I really don't
understand why. But I guess mapserver needs to know the units of the
original extent when requesting various other projections.
And I love the 'AUTO' as I have tens of thousands of images, all with
different projection! So even if it will cost me my sanity i think I
will go with that :-)
Trygve
Den 2022-05-19 16:10, skrev Jeff McKenna:
> Hi Trygve,
> You can examine the problem QGIS GetMap request closely, through the
> Network Logger (it's really a saviour)
> https://github.com/mapserver/mapserver/wiki/Get-the-Raw-WMS-Request-Generated-by-QGIS
> Then you can go back to review the trusty WMS Server document, and
> make sure you have set the required metadata:
> https://mapserver.org/ogc/wms_server.html
> (which also means to remove all warnings from your GetCapabilities
> response)
> But that QGIS network logger is your lifeline :)
> Hope that gets you started,
> PS. I never use 'auto', ever, never, it's my own rule and that's how I
> keep my sanity and avoid these issues, ha.  But others like it.  I
> only speak for myself here.
> -jeff
> Jeff McKenna
> GatewayGeo: Developers of MS4W, MapServer Consulting and Training
> co-founder of FOSS4G
> http://gatewaygeo.com/
> On 2022-05-19 10:26 a.m., Trygve Aspenes wrote:
>> Hi
>> I got a geotiff raster with a projection which is not an EPSG code, so
>> in the mapfile I use AUTO in the layer projection. This also means I
>> skip the extent and projection in map level in the mapfile. In one
>> client this works fine ( this client request epsg:3857 and this looks
>> fine to me)
>> But in QGIS, this does not work nor any other projections.
>> Then I add EXTENT and PROJECTION in my mapfile like this:
>> MAP
>>    EXTENT -56.6378419 31.5007307 95.025531 84.6828537
>>    PROJECTION
>>      "init=epsg:4326"
>>    END
>> END
>> And then EPSG:4326 works in QGIS also. But if I try to change the
>> projection i qgis, eg to EPSG:3857, this does not work in QGIS, even
>> if it still work in my other client.
>> So what is it that I don't understand about EXTENT and PROJECTION. I
>> have looked at the documentation
>> https://mapserver.org/mapfile/projection.html#important-notes and and
>> as far as I can understand from the second bullet point the projection
>> definition at map level can be looked as the outgoing projection with
>> the extent accordingly.
>> What do I need to do to make QGIS be able to use other projections as
>> well?
>> I do have a link to my getcapabilities document, but hesitates to put
>> it here.
>> Trygve Aspenes
> MapServer-users mailing list
> MapServer-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
