[MapServer-users] readGIF error meaning ?
Jean-Christophe Bastin jcbastin at thelis.be
Fri Nov 25 01:37:20 PST 2022
Hello Jeff,
Thanks for the reply.
Your answer was in my junk folder, sorry for the delay ^^'
I found where the error was coming from, if it can interest someone else.
My MapFile has thematics (many CLASS with EXPRESSION in LAYER), and some cases use an external GIF resource defined in my SYMBOLSET.
It was not well defined, and I also have to change these from GIF to PNG, and now all works well.
Best regards
JCB
-----Message d'origine-----
De : MapServer-users <mapserver-users-bounces at lists.osgeo.org> De la part de Jeff McKenna
Envoyé : lundi 7 novembre 2022 18:08
À : mapserver-users at lists.osgeo.org
Objet : Re: [MapServer-users] readGIF error meaning ?
Hello JC,
If you are using MS4W, you can test a GetLegendGraphic request by using the local demo WMS service that comes with every MS4W install, out-of-the-box, such as:
https://ms4w.dev/cgi-bin/mapserv.exe?MAP=/ms4w/apps/local-demo/local.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=getlegendgraphic&layer=countries&FORMAT=image/png
(you should be able to modify the url above for 127.0.0.1/ instead)
If that works locally for you, just follow the local-demo.map, for your own mapfile.
-jeff
Jeff McKenna
GatewayGeo: Developers of MS4W, MapServer Consulting and Training co-founder of FOSS4G http://gatewaygeo.com/
On 2022-11-07 11:23 a.m., Jean-Christophe Bastin wrote:
> Hello,
> I have many map files and I’m trying to get legends from them.
> I followed the documentation I found :
> https://mapserver.org/ogc/wms_server.html#getlegendgraphic-request
> <https://mapserver.org/ogc/wms_server.html#getlegendgraphic-request>
> The map file I test follows the requirements. I tried many calls :
> http://127.0.0.1/cgi-bin/mapserv.exe?MAP=C:/mywms.map&SERVICE=WMS&layer=mylayer&REQUEST=getlegendgraphic&FORMAT=image/png&VERSION=1.0.0 <http://127.0.0.1/cgi-bin/mapserv.exe?MAP=C:/mywms.map&SERVICE=WMS&layer=mylayer&REQUEST=getlegendgraphic&FORMAT=image/png&VERSION=1.0.0>
> http://127.0.0.1/cgi-bin/mapserv.exe?MAP=C:/mywms.map&SERVICE=WMS&layer=mylayer&REQUEST=getlegendgraphic&FORMAT=image/png&VERSION=1.1.0 <http://127.0.0.1/cgi-bin/mapserv.exe?MAP=C:/mywms.map&SERVICE=WMS&layer=mylayer&REQUEST=getlegendgraphic&FORMAT=image/png&VERSION=1.1.0>
> http://127.0.0.1/cgi-bin/mapserv.exe?MAP=C:/mywms.map&SERVICE=WMS&layer=mylayer&REQUEST=getlegendgraphic&FORMAT=image/png&VERSION=1.1.1 <http://127.0.0.1/cgi-bin/mapserv.exe?MAP=C:/mywms.map&SERVICE=WMS&layer=mylayer&REQUEST=getlegendgraphic&FORMAT=image/png&VERSION=1.1.1>
> http://127.0.0.1/cgi-bin/mapserv.exe?MAP=C:/mywms.map&SERVICE=WMS&layer=mylayer&REQUEST=getlegendgraphic&FORMAT=image/png&VERSION=1.3.0&SLD_VERSION=1.1.0 <http://127.0.0.1/cgi-bin/mapserv.exe?MAP=C:/mywms.map&SERVICE=WMS&layer=mylayer&REQUEST=getlegendgraphic&FORMAT=image/png&VERSION=1.3.0&SLD_VERSION=1.1.0>
> Each of them give me the error :
> readGIF(): General error message. corrupted gif image?: Failed to read
> from file
> What does that mean ? Am I missing a parameter in my call or something
> more in the map file that is not in the documentation ?
> Or is it the kind of generic error “I can’t generate your legend, just
> find by yourself why” ? XD
> Many thanks !
> *JCB*
MapServer-users mailing list
MapServer-users at lists.osgeo.org
https://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users mailing list
