[MapServer-users] Shapefile data source doesn't work
Jörg Thomsen (WhereGroup) joerg.thomsen at wheregroup.com
Tue Nov 29 07:31:02 PST 2022
the pastebin-mapfile has no class and styling information. you need at
least one class with one style.
-> https://mapserver.org/tutorial/example1-2.html
Jörg
Am 29.11.22 um 16:20 schrieb Marcin Niemyjski:
> Jörg,
> I meant that when checking in qgis no data is rendered, nothing is
> shown. I just tried:
> https://pastebin.com/zgNes8PD <https://pastebin.com/zgNes8PD>
> QGIS connects with layer, but it seems like there is no data.
> and result remain the same - nothing was received.
> Thank you for fast reply,
> Marcin
> *From:* MapServer-users <mapserver-users-bounces at lists.osgeo.org> on
> behalf of Jörg Thomsen (WhereGroup) <joerg.thomsen at wheregroup.com>
> *Sent:* Tuesday, November 29, 2022 4:08 PM
> *To:* mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
> *Subject:* Re: [MapServer-users] Shapefile data source doesn't work
> Hi,
> for shp you don't need connectiontype and connection, only data is
> required. Try the absoulte path to your shp.
> Wht do you mean with 'map does not show'? white / blank image? This is
> often caused by a mismatsch bewtween epsg und extent. Or an error-msg?
> what does it say?
> Jörg
> Am 29.11.22 um 15:52 schrieb Marcin Niemyjski via MapServer-users:
>> Hello,
>> I have a problem rendering vector layer. The data does not show. My mapfile:
>> MAP
>> NAME "AED"
>> EXTENT 1584202.7350061805918813 6301803.1952485935762525
>> 2675789.3720532376319170  7329216.3261622246354818
>> UNITS METERS
>> SIZE 512 512
>> IMAGETYPE PNG
>> SHAPEPATH "/data/"
>> PROJECTION
>>      "init=epsg:3857"
>> END
>> WEB
>>      IMAGEPATH "/tmp/"
>>      IMAGEURL "/tmp/"
>>      METADATA
>>        "wms_title"           "AED"
>>        "wms_onlineresource"  "***" #must change mapfile path
>>        "wms_srs"             "EPSG:3857"
>>        "wms_enable_request"  "*"
>>        "wms_server_version" "1.3.0"
>>        "wms_feature_info_mime_type" "text/html"
>>        "wms_include_items" "all"
>>        "wms_getcapabilities_version" "1.3.0"
>>      END
>> END
>> LAYER
>>    NAME "my_shapefile"
>>    STATUS ON
>>    TYPE POINT
>>    STATUS ON
>>    CONNECTIONTYPE OGR
>>    CONNECTION "/DyskPlanetiler/OSM/aed_poland.shp"
>>    DATA "aed_poland"
>>    CLASS
>>        NAME "AED"
>>        STYLE
>>          COLOR 246 241 223
>>          OUTLINECOLOR 255 0 0
>>          SYMBOL 'circle'
>>          SIZE 20
>>        END
>>      END
>>    END
>> END
>> I will be grateful for any tips.
>> Best,
>> Marcin
>> MapServer-users mailing list
>> MapServer-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
> <https://lists.osgeo.org/mailman/listinfo/mapserver-users>
> Viele Grüße,
> Jörg Thomsen
> Where2B Konferenz 2022
> 15. Dezember 2022 in Bonn und Online
> where2b-conference.com
> Jörg Thomsen
> WhereGroup GmbH
> Bundesallee 23
> 10717 Berlin
> Germany
> Tel: +49 (0)30 / 5130 278 74
> Fax: +49 (0)30 / 5130 278 11
> www.wheregroup.com <http://www.wheregroup.com>
> Geschäftsführer:
> Olaf Knopp, Peter Stamm
> Amtsgericht Bonn, HRB 9885
> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
> <http://twitter.com/WhereGroup_com>
Viele Grüße,
Jörg Thomsen
Jörg Thomsen
WhereGroup GmbH
Bundesallee 23
10717 Berlin
Germany
www.wheregroup.com
Geschäftsführer:
More information about the MapServer-users mailing list
