[MapServer-users] Projection confusion and output image format
Rahkonen Jukka jukka.rahkonen at maanmittauslaitos.fi
Thu Oct 13 01:03:21 PDT 2022
You will see the srs metadata in GetCapabilities, WMS clients can build a menu according to the list, and Mapserver will reproject the maps. At least if you make a list that makes sense, it is not possible to transform EPSG:3067 into all coordinate systems of the World.
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: Stefan Gofferje <lists at home.gofferje.net>
> So just to be sure: "wms_srs" is not only setting metadata but actually also configuring what reprojections mapserver will do?
-Stefan
More information about the MapServer-users mailing list
